At what height objects will pass each other?
  • Thread starter Thread starter patelneel1994
    Height
Two objects are in motion: one is thrown downward from 60 m with an initial speed of 10 m/s, and the other is propelled upward from ground level at 40 m/s. To find the height at which they pass each other, the equation d = Vi . t + 1/2 a t² is used, with adjustments for their starting heights. The calculated height where they meet is confirmed to be 41 m above the ground. A quicker method involves recognizing their constant relative velocity of 50 m/s to determine the time until they meet.
patelneel1994
An object is thrown downward with an initial (t = 0) speed of 10 m/s from a height of 60 m above the ground. At the same instant (t = 0), a second object is propelled vertically upward from ground level with a speed of 40 m/s. At what height above the ground will the two objects pass each other?
first object
t0 = 0
V = 10 m/s
H = 60
Second object
t0 = 0
V = 40 m/s
H = 60
d = Vi . t + 1/2 a t2
This equation doesn't see me to work since we need to find at which height objects will pass
hi patelneel1994! :wink:
call the height of either object above the ground "d", and rememb
er that the two objects start at different values of d …
show us what you get :smile:
So instead of d I should put h. Find height for each object separately!
d or h, it doesn't matter, so long as you use the same symbol for each, but start them at different values :wink:
Likes 1 person
I got 41 m. Thanks
patelneel1994 said:
I got 41 m. Thanks
I confirm that answer. A slightly quicker way, perhaps, is to note that the two objects undergo the same acceleration, so the relative velocity is constant. The closing speed is therefore a constant 10+40=50 m/s. That tells you how long they take to meet.
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
