At what phase is the heat capacity the greatest?
Heat capacity varies by phase, with solids generally having lower heat capacities than liquids and gases. Water is noted as an exception, exhibiting its highest heat capacity in the liquid state due to hydrogen bonding. The overall rule suggests that liquids typically have greater heat capacities than solids, while gases have the highest heat capacities among the three phases. This is attributed to the increased freedom of movement and energy absorption in liquids and gases compared to solids. Understanding these differences is crucial for applications in thermodynamics and material science.
Anna55
At what phase is the heat capacity the greatest? Is it when the substance is a solid, liquid or gas? Please also explain why.
I believe that the heat capacity is the greatest when the subastance is a solid.
What about water?
For water the heat capacity is the greatest when it is a liquid. However is not water an exception? What is the overall rule?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
