MHB At which p-adic fields does the equation have no rational solution?
  • Thread starter Thread starter evinda
    Fields Rational
The equation $3x^2 + 5y^2 - 7z^2 = 0$ has been shown to lack non-trivial solutions in $\mathbb{Q}$, particularly verified through the case of $p=3$. To determine at which p-adic fields it has no rational solution, the Hilbert symbol $\left( \frac{3}{7}, \frac{5}{7} \right)_p$ must be computed for various primes. The discussion emphasizes the importance of checking primes $p=3, 5, 7, \infty$ for potential solutions. Concerns were raised regarding the understanding of the Hilbert symbol and alternative methods for larger primes.
evinda
MHB
Hello! (Wave)I have to check if the equation $3x^2+5y^2-7z^2=0$ has a non-trivial solution in $\mathbb{Q}$. If it has, I have to find at least one. If it doesn't have, I have to find at which p-adic fields it has no rational solution.Theorem:
We suppose that $a,b,c \in \mathbb{Z}, (a,b)=(b,c)=(a,c)=1$.
$abc$ is square-free. Then, the equation $ax^2+by^2+cz^2=0$ has a non-trivial solution in $\mathbb{Q} \Leftrightarrow$
  1. $a,b,c$ do not have the same sign.
  2. $\forall p \in \mathbb{P} \setminus \{ 2 \}, p \mid a$, $\exists r \in \mathbb{Z}$ such that $b+r^2c \equiv 0 \pmod p$ and similar congruence for the primes $p \in \mathbb{P} \setminus \{ 2 \}$, for which $p \mid b$ or $p \mid c$.
  3. If $a,b,c$ are all odd, then there are two of $a,b,c$, so that their sum is divided by $4$.
  4. If $a$ even, then $b+c$ or $a+b+c$ is divisible by $8$.
    Similar, if $b$ or $c$ even.
The first sentence is satisfied.
For the second one:
$$p=3:$$
$$5+x^2(-7) \equiv 0 \pmod 3 \Rightarrow x^2 \equiv 2 \mod 3$$
$$\left ( \frac{2}{3} \right)=-1$$So, we see that the equation hasn't non-trivial solutions in $\mathbb{Q}$.
But.. how can we check at which p-adic fields the equation has no rational solution?
Mathematics news on Phys.org
Divide out and write,
$$ \tfrac{3}{7}x^2 + \tfrac{5}{7}y^2 - z^2 = 0 $$
If there is a non-trivial solution in $\mathbb{Q}_p$ it means that the Hilbert symbol, $\left( \tfrac{3}{7},\tfrac{5}{7}\right)_p = 1$. Now you need to compute the Hilbert symbol for various primes $p$.
Now the Hilbert symbol can be multiplied through by a square without changing it. So we can clear denominators by multiplying through by $7^2$ and get $(21,35)_p=1$. Really the only primes you need to check are $p=3,5,7,\infty$. Do you understand why?
I haven't get taught the Hilbert symbol. (Worried) How else could we do this? (Thinking)
For $p=2,3,5,7$, we can write the congruence modulo $p$ and we can see if there is a solution or not.
But, what can we do for $p>7$ ? (Thinking)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
