Atwood Machine: Reduce Exp Errors By Stabilizing Masses
Tying a string of equal length to the string connecting the pulley and the masses helps reduce experimental errors by ensuring that both masses drop the same distance simultaneously. This setup stabilizes the motion, minimizing discrepancies caused by uneven acceleration or external forces. The discussion highlights the importance of understanding the assumptions of an ideal Atwood machine and the factors that prevent achieving perfect conditions. Participants express confusion about the specific experimental errors and how the string influences them. Overall, the conversation emphasizes the need for clarity on the mechanics involved in Atwood machines to improve experimental accuracy.
wiccabean21
String that is equal in length to the string connecting the pulley is sometimes tied to the bottoms of the two masses, where it hangs suspended between them. Explain why this would reduce experimental errors.
I'm not sure but does the string help stabalize the masses when one is dropped so they travel the exact same distance?
The question asks why it helps to reduce experimental errors. It's not referring to mechanically stabilizing anything.
What are the assumptions for an ideal Atwood Machine? What keeps you from being able to build an ideal/perfect AM? What could you do to mitigate these imperfections?
http://en.wikipedia.org/wiki/Atwood_machine
But I don't understand what the experimental errors are... how could string have affected it in any way?
Did you read the link that I posted? The clues are in there. (Or in your textbook's description of the AM)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
