Atwood's machine height problem
  • Thread starter Thread starter tony873004
    Height Machine
In the discussion about Atwood's machine, the user calculates the acceleration of the system using the masses m1 and m2, finding it to be approximately 1.06054 m/s². They then apply the kinematic equation to determine the height m2 rises before coming to rest, calculating a distance of 1.36 cm. However, this result is marked incorrect by the online homework system, raising questions about the accuracy of the grading. The user notes that a similar problem in the textbook yields a different height of 4 cm, despite using the same method. The conversation highlights potential discrepancies in online grading and suggests that using work-energy principles might simplify the problem.
tony873004
Figure 8-20 http://www.webassign.net/walker/08-20b_alt.gif
14. [Walker2 8.P.025.] For the Atwood's machine shown in Figure 8-20, suppose that m2 has an initial upward speed of v = 0.17 m/s.
How high does m2 rise above its initial position before momentarily coming to rest, given that m1 = 3.3 kg and m2 = 4.1 kg?
Here's what I did:
F_{1} = T - m_{1}g = m_{1}a
F_{2} = m_{2}g - T = m_{2}a
and since the tensions must equal each other
(m_{2} - m_{1})g = (m_{1} + m_{2})a
or
a = \frac{m_{2} - m_{1}}{m_{1} + m_{2}} g
a = \frac{4.1 - 3.3}{3.3 + 4.1} 9.81
a = 1.06054
I'm pretty confident that the answer is correct so far because the book uses this exact method in their example. Only the masses and velocity are changed. But the book's example stops at acceleration. Our problem asks for a distance, so...
d = \frac{\Delta V^2}{2a}
d = \frac{0.17^2}{2*1.06054}
d = 0.0136 m
d = 1.36 cm
But Webassign, the online homework system says WRONG :mad:
But the same problem in the book, using m_{1}=3.7 , m_{2} = 4.1 , v = 0.2 gives an answer of 4cm, which is exactly what I get using the same method. How can this method be good using the book's numbers, but wrong using the numbers in the online problem? Could the online grading be wrong? :bugeye: Wouldn't be the first time :-p
hmm not sure
Its much easier if you use work energy to solve this problem. Also the tensions are not equal- only in the static case but the relative position, velocity, and acceleration are.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
