Audacity : Record stereo that is playing in browser
  • Thread starter Thread starter Swamp Thing
The discussion focuses on recording stereo audio from a Chromium browser using Audacity on a Raspberry Pi 5. The user encounters an issue where only one volume slider appears in Pulse Audio Volume Control, indicating a potential problem with stereo recording setup. Despite starting a stereo track in Audacity, both channels output the same sound, suggesting a limitation in the audio configuration. The user questions whether the mono microphone setup might be affecting Audacity's ability to record in stereo. Additional comments mention similar issues with MIDI configuration and the need to check Pulse Audio settings for proper channel setup.
Swamp Thing
Insights Author
I am running Audacity on a Raspberry Pi 5.
I am following the steps given here https://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_linux.html
trying to record in Audacity a stereo track playing in Chromium browser. This sound is concurrently being sent to a speaker via "USB Audio Device Analog Stereo", whose "monitor" channel outputs the signal that I want.
My problem is that when I go to Pulse Audio Volume Control -> Recording and select USB Audio Device Analog Stereo as my recording source, I see only one single volume slider. The instructions, however, say that two volume controls should appear if stereo recording is working correctly.
In Audacity, I am able to start up a stereo recording track, but both tracks contain the same sound (the sum of the left and right signals from the browser). The single PAVU volume slider controls both their levels.
Am I missing some obscure setup option that needs to be changed? Or is it a basic limitation of Aucacity on the Pi?
My audio hardware is a USB sound device with stereo playback and mono microphone. Is the mono mic configuration somehow forcing Audacity to work in mono, even when the source is not from the USB device? If so, can this be overridden to get stereo?
Computer science news on Phys.org
Since noone offered any help I’ll just throw my 1 cent in there ….
I’ve had a similar problem setting up MIDI. Have you configured Pulsar to use 2 channels? Cause that is the error message I keep getting.
I will look up more info on pulse config and see if there is something that helps, thanks.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
