Autonomous differential equation
In summary, if the equilibrium depth is greater than the initial volume, then the volume will increase without limit. If the equilibrium depth is less than the initial volume, then the volume will decrease without limit.
jellicorse
40
A pond forms as water collects in a conical depression of radius a and depth h. Suppose water flows in at a constant rate, k and is lost through evaporation at a rate proportional to the surface area.
I was wondering whether anyone could give me some guidance on this part of the question:
Find the equilibrium depth of water in the pool. Is the equilibrium asymptotically stable?
[tex]\frac{dV}{dt}=k-\alpha \pi(\frac{3aV}{\pi h})^{\frac{2}{3}}[/tex]
Where [tex]\alpha[/tex] = coefficient of evaporation.
radius at any time r(t) and depth at any time l(t).
[tex]\frac{a}{h}=\frac{r}{l}[/tex]
[tex]\frac{dV}{dt}=0=k-\alpha \pi(\frac{3aV}{\pi h})^{\frac{2}{3}}[/tex]
Putting the differential equation only in terms of radius and alpha:
[tex]\alpha \pi r^2 =k[/tex]
[tex]r=\sqrt{(\frac{k}{\alpha \pi})}[/tex]
given that [tex] l=r\cdot\frac{h}{a}[/tex],
[tex]l=\frac{h}{a}\sqrt{(\frac{k}{\alpha \pi})}[/tex]
But I am not sure how to find whether or not this is asymptotically stable.
Consider initial conditions near the equilibrium point.
If initially the volume is a little bit larger than the equilibrium volume, does the volume come back to equilibrium, or does it increase without end?
And the reverse, if the initial volume is a little bit smaller than the equilibrium volume?
You could also linearize the equation around the equilibrium point and answer the same questions, easily.
Thanks Maajdl.
I can see that solving for V, the equilibrium volume is [tex]V=\frac{\pi h}{3a}(\frac{k}{\alpha \pi})^{\frac{3}{2}}[/tex]
But without picking some arbitrary values and plotting a direction field (or plotting Dv against V) I am not sure how to tell whether the volume diverges or converges to equilibrium.
(I haven't yet studied linearisation so am not quite ready to use this option)
Assume Vo is the equilibrium volume.
If V>Vo, will the evaporation overcome the water supply and bring V back to Vo?
If V<Vo, will the water supply overcome the evaporation to bring V back to Vo?
This site may inspire you:
http://tutorial.math.lamar.edu/Classes/DE/EquilibriumSolutions.aspx
The situations described there are a little bit more complicated, but the same reasoning will apply.
The pictures shown there are useful to visualize what will happen.
Such "phase space flows" are more general than this one variable problem, and are at the hearth of the stability theory of differential equations. (and are even related to top mathematical physics, like the KAM theorem)
Likes 1 person
Thanks a lot maajdl... I'll have a good look through that webpage too. I need to get to grips with this topic!
It is much, much easier to look at [itex]dl/dt[/itex] (as you are strongly hinted to do by the instruction to find the equilibrium depth, not the equilibrium volume). Since
[tex]
r = \frac{al}{h}
[/tex]
we have
[tex]
V = \frac{\pi}{3}r^2 l = \frac{\pi a^2}{3h^2} l^3
[/tex]
and hence
[tex]
\frac{dV}{dt} = \frac{\pi a^2}{h^2} l^2 \frac{dl}{dt}.
[/tex]
Writing [itex]k = \frac{\pi a^2}{h^2}\alpha C^2[/itex] and using [itex]r^2 = a^2l^2/h^2[/itex] in the ODE gives
[tex]
\frac{dV}{dt} = \frac{\pi a^2}{h^2}\alpha C^2 - \alpha \frac{\pi a^2}{h^2} l^2
= \frac{\pi a^2}{h^2} \alpha\left(C^2 - l^2\right)
[/tex]
so that
[tex]
\frac{dl}{dt} = \alpha\left(\frac {C^2}{l^2} - 1\right)
[/tex]
where, of course,
[tex]
C = \frac{h}{a} \sqrt{\frac{k}{\pi \alpha}}.
[/tex]
No linearization is necessary here; just sketch a graph of [itex]dl/dt[/itex] against [itex]l[/itex], and see what the sign of [itex]dl/dt[/itex] is immediately above and below the fixed point.
Likes 1 person
It is also possible to sketch the graph of dV/dt against V .
[tex]
[/tex]
so that
[tex]
[/tex]
Thanks, Pasmith. After studying it, I can see what you have done. The thing that concerns me is that it wouldn't have occurred to me to make these steps. You must be thinking several steps ahead, visualizing how it will all fit together...
That's true... I would quite like to try to see if I can get it symbolically though.
All you need is exercise.
These steps are very standard and will see them again and again, specially in classical mechanics.
Choosing l instead of V as variable would be highly natural if you would like to study if overflow might occur!
Related to Autonomous differential equation
What is an autonomous differential equation?
An autonomous differential equation is a type of differential equation where the independent variable does not appear explicitly. This means that the equation does not depend on any specific value of the independent variable, but rather on the relationship between the dependent and independent variables.
How is an autonomous differential equation different from a non-autonomous differential equation?
In a non-autonomous differential equation, the independent variable is explicitly present in the equation. This means that the equation depends on a specific value of the independent variable, rather than the relationship between the variables. Autonomous differential equations are often used to model systems that have no external time dependence.
What is the general form of an autonomous differential equation?
The general form of an autonomous differential equation is dy/dx = f(y). This means that the rate of change of the dependent variable y is equal to some function f(y). This function can be any mathematical expression involving y, such as a polynomial or trigonometric function.
What are some real-world applications of autonomous differential equations?
Autonomous differential equations have many real-world applications, including modeling population growth, chemical reactions, and electrical circuits. They are also commonly used in physics to model systems such as pendulums and springs.
How are autonomous differential equations solved?
There is no single method for solving all autonomous differential equations, as the approach depends on the specific equation and its form. Some techniques that may be used include separation of variables, substitution, and numerical methods such as Euler's method. In some cases, autonomous differential equations may not have an analytical solution and require numerical methods to approximate the solution.
