Average Current Through A Coil Over An Interval
In summary, the conversation discusses a problem involving finding the average current through a coil over a 3 second interval. The solution involves calculating the EMF using the formula E = NAB and then using Ohm's Law to find the current. However, there is some discussion about whether the EMF increases linearly or not. Eventually, it is determined that the EMF is constant over the 3 seconds and the average current is calculated using the formula i = V/R. The final result is 7.363x10^-4 A.
rzermatt
[SOLVED] Average Current Through A Coil Over An Interval
The problem comes from a homework assignment I have. It has to deal with average current flowing through a wire over an interval. It is stated as follows:
A five-turn circular coil of radius 15cm is oriented with its plane perpendicular to a uniform magnetic field of 0.15T. During a 3s time interval, this field increases to 0.2T. If the resistance of the coil is 8[tex]\Omega[/tex], find the average current that flows in the coil during this interval.
I know that to find EMF in a setting like this:
E = NAB [The rest doesn't matter since it is perpendicular]
V = iR [Ohm's Law]
Let E1 be before the change, and E2 at the end.
E = NAB
E1 = (5 Turns)(pi*(0.15m)^2)(0.15T) = .0530V
E2 = (5 Turns)(pi*(0.15m)^2)(0.2T) = .0707V
Using these numbers, V = iR and the known resistance, the currents are as follows:
I1 = (.0530V)/(8Ohm) = 0.006625A
I2 = (.0707V)/(8Ohm) = 0.008837A
The average between them over 3 secs, is I1+I2/3s or:
(0.006625A+0.008837A)/3s = 0.005154A
Is my methodology correct? For some reason I feel I may be doing this incorrectly. Any help would be much appreciated.
The computation of the average makes no sense. You have current/time in A/s, and yet somehow you call this quantity a current. It's not dimensionally consistent.
The average current would be equal to the total charge that flowed across the coil in the 3s time interval, divided by the time interval. In other words, it would be equal to the integral of the instantaneous current i(t) with respect to time (from t = 0 to t = 3 s) divided by the time interval.
Now, the question is, what is i(t)? Well, IF the EMF increases linearly, then since Ohm's law applies in this situation, then we can say that the current increases linearly, in which case the integral is fairly straightforward. Whether the EMF increases linearly or not depends upon whether the magnetic field increases linearly.
But actually, that's not true. I think your formula for the induced EMF is wrong (E=NAB). The EMF is not proportional to the magnetic field. It is proportional to the rate of change of the magnetic field (E = NAdB/dt, perhaps). Only a magnetic field that is changing with time produces an EMF.
If that is the case, then provided that the magnetic field increases linearly, the voltage (induced EMF) will be *constant* over the 3 seconds, and so will the current. That simplifies the problem.
Alright... that took a few minutes to make sense of.
Allow me to explain my recalculations:
[tex]\Phi[/tex] = BACos([tex]\Theta[/tex])
Emf = -N([tex]\Delta[/tex][tex]\Phi[/tex]/[tex]\Delta[/tex]t)
Thus:
[tex]\Delta[/tex][tex]\Phi[/tex] = (0.15T*(pi*(.15)^2)) - (0.2T*(pi*(.15)^2)) = -0.003534
EMF = -(5 Turns)*(-0.003534)/3s = .00589V
The average current would be:
i = V/R
i = (.00589V)/8[tex]\Omega[/tex] = 7.363x10^-4 A
I hope this is correct.
The method looks alright to me. I didn't really double check the calculations.
No problem. I just wanted to really make sure that my concepts were correct. I can always recheck the number as I write it down in my actual homework.
Thanks for all the help! Greatly appreciated.
FAQ: Average Current Through A Coil Over An Interval
1. What is average current through a coil over an interval?
The average current through a coil over an interval is the measure of the flow of electric charge over a specific period of time. It is calculated by dividing the total charge that passes through the coil by the time interval.
2. Why is measuring average current important in a coil?
Measuring average current in a coil is important because it helps to determine the strength of the magnetic field produced by the coil. It is also crucial for understanding the behavior of the coil in circuits and inductive loads.
3. How is average current through a coil different from instantaneous current?
Average current is the measure of the total charge passed through the coil over a period of time, while instantaneous current is the value of the current at a specific moment in time. Average current takes into account the fluctuations in the current over time, while instantaneous current only gives a snapshot of the current at that particular moment.
4. What factors affect the average current through a coil?
The average current through a coil can be affected by several factors such as the voltage applied to the coil, the resistance of the coil, and the number of turns in the coil. Any changes in these factors can alter the average current through the coil.
5. How can the average current through a coil be increased?
The average current through a coil can be increased by either increasing the voltage applied to the coil or decreasing the resistance of the coil. This can be achieved by using a higher voltage source or using a coil with a lower resistance. However, it is important to note that increasing the current beyond the rated limit can damage the coil and potentially cause it to overheat.
