Average power (counterweight, tension, motor)
The discussion revolves around calculating the average power generated by a motor in a material hoist system with a total mass of 600 kg and a counterweight of 150 kg. The user attempts to determine the acceleration and tension forces but encounters confusion regarding the calculations, particularly with the tension in the ropes and the application of motor efficiency. They correctly identify the average velocity but are unsure whether to multiply or divide by the efficiency factor of 0.8. Ultimately, the correct average power output is noted to be 10.1 kW, highlighting the importance of accurate calculations in physics problems. Clarification on the use of units and the concept of power generation is also requested.
jamesweston0
The material hoist and the load have a total mass of 600 kg and the counterweight C has a mass of 150 kg. If the upward speed of the hoist increases uniformly from to 0.9 m/s to 2.3 m/s in 2 s, determine the average power generated by the motor M during this time. The motor operates with an efficiency of e = 0.8.
F = ma
P = Fv
e = energy output / energy input
This question doesn't seem like it's too hard but I still am stuck! I feel like I am close though so I would appreciate some insight. Great forum this is!
I first figured out the acceleration of the system by using this:
(Vf - Vi)/t = a
(2.3 - 0.9)/2 = a = 0.7
I then looked at the counterweight and figured out the tension in the left rope. Equation looked like this:
W - Tc = ma
(150*9.8) - Tc = (150*0.7)
Tc = 1365 N
I then looked at the main weight. I think I screwed up on the tension forces. I used the 600kg for the masses. This is what I did:
Tc + 2Tm - mg = ma
1375 + 2Tm - (600*9.8) = (600*0.7)
-4515 + 2T = 420
T = 2467.5 N
I multiplied this by the average velocity, which I found by adding the initial and final velocities, and then dividing by 2.
2467.5*1.6 = 3948 N
I then took this number and divided by 0.8 to get the amount generated. I'm also not sure if I'm supposed to multiply here or divide because I'm confused by what generated means. Silly thing I know. But it doesn't really make a difference whether I multiply or divide by 0.8 at this point because I have already messed up earlier on somewhere.
Can someone explain where I am flawed in my thinking? I really want and need to understand this stuff thoroughly. Thanks a ton!
The unit for power is Watt and not Newton.
In rest it seems OK.
Oops yeah I screwed up there. But the answer is actually 10.1 kW.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
