- #106
billschnieder
- 808
- 10
Okay so we can linearly combine them. But it is nontrivial for non-commuting observables. The issue is not that we can not combine them but that we don't expect a trivial substitution to work. Like I said, there is no problem with the substitution if we interpret is as corresponding to 4 isolated systems, but as you can see above, the inequality is different, S <= 4. The problem only arises if you interpret the substitution as pertaining to the same system for which S <=2. So when it is said that QM violates the S <= 2 inequality, it is suspect because if we carry that argument, we would have to treat the substitution as pertaining to the same system and we end up with an expression that has no solution because it is impossible to find an eigenvector for that specific combination of observables.bhobba said:Here we are considering the quantum formalism in which the addition of expectation values is true.
You can factorize that linear combination and end up with an expression of the form
##\langle A_a(B_b - B_{b'}) + A_a'(B_b + B_{b'})\rangle## which is an expression of the form
##\hat{A}\otimes\hat{B} + \hat{C}\otimes\hat{D}##
If it has a solution, should satisfy
##\hat{A}|\phi\rangle\otimes\hat{B}|\chi\rangle + \hat{C}|\phi\rangle\otimes\hat{D}|\chi\rangle = \alpha(|\phi\rangle\otimes|\chi\rangle)##
But the LHS cannot be factored since the ##[\hat{A},\hat{C}] ≠0## and ##[\hat{B},\hat{D}] ≠0## so there is no solution. It is a meaningless expression for a single system.
