Back EMF vs Reverse Currents: What's the Difference?
Back EMF and reverse currents are distinct concepts in electrical engineering, with Back EMF referring to the voltage generated by a motor that opposes the applied voltage, while reverse current pertains to current flowing in the opposite direction. Reverse saturation current is a specific term used in semiconductor physics, indicating the small current that flows through a diode when reverse-biased. Backfeeding describes a situation where power flows back into a source, often seen in power distribution systems. The discussion highlights the complexity and varied applications of these terms across different electrical engineering fields. Understanding the differences requires a more focused inquiry into each concept's specific context.
Benjamin_harsh
Are these 4 terms in electrical subject are same?
Is it Back EMF, Reverse Current, Reverse Saturation current, Backfeeding? If not, tell the difference.
Well, EMF can't be the same as current. can it?
I have just googled these 4 terms and found definitions of them. (No, they are not the same.) Have you tried that?
Likes DaveE and berkeman
No. Could you ask a more specific question? These terms cover a wide range of subjects in EE as I interpret them; Motors/Magnetics, Semiconductors, Power Distribution... It just too hard to describe everything in one post.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
