Bacteria Colony Distribution in a Nutrient Dish
The discussion focuses on calculating the distribution of bacterial colonies formed on a nutrient dish after a drop of water containing 2000 bacteria is smeared over its surface. The Poisson distribution is suggested as the appropriate model for this scenario, given the random and independent nature of bacterial placement. An alternative approach using the binomial distribution is also mentioned, where the number of successes corresponds to finding specific bacteria in the drop. The mean number of colonies is a critical factor in both distributions. Understanding these statistical models is essential for accurately predicting colony distribution on the dish.
Redhead711
Hello, I have been stuck on this problem for about a week and a half. I was wondering if there was anyone out there who might understand it and explain it clearly to me.
Suppose a volume of 1000 drops of water contains 2000 bacteria, separate from each other and thoroughly mixed in the water. A single drop is smeared uniformly over the surface of the dish. The dish contains nutrients on which the bacteria feed and multiply. After a few days, wherever a bacterium was deposited on the dish a visible colony of bacteria appears. Find the distribution of the number of colonies that appear. (a) over the whole plate, and (b) over an area of half the plate.
You should use the Poisson distribution. You know what the mean should be?
Or to be exact, you could use the binomial distribution where each success is finding a particular bacterium of the 2000 in the drop, so n = 2000 and you can figure out p. But the Poisson should be very accurate.
Thank you very much for your help
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
