How Did 1886 Dutch Students Solve This Complex Math Problem?
In summary: What is partial integration? You mean like this? $$\int \mathrm{f}(x,y,z) \partial{}x$$or this$$\int u\, dv=u\, v-\int v\, du$$maybe your friend should work on his communication skills. The student probably did not know what he was on about. What is forth semester physics these days? Is that still incline planes or maybe finite square wells?From what I understand, partial integration is the process of integrating a function over a region of a two-dimensional space. Integration by parts is the process of integrating a function over a part of a two-dimensional space
BvU
16,139
4,889
Solve ##x## from $$\left ( a+x\right )^{2\over 3} + 6\left ( a-x\right )^{2\over 3} =5\left ( a^2- x^2 \right )^{1\over 3} $$
actually, my algebra appears insufficient :frown:
Book answer is ##\qquad a≥0\qquad x={ 7\over 9}\;a\ \ \lor\ \ x={ 13\over 14}\;a\ \ ##but I fail to see how to get there !
Stunned by an 1886 dutch high school exam exercise. Hats off for the 17 year olds that did it !
Divide by the right hand side.
  • Love
Likes chwala, WWGD, SammyS and 2 others
I don't get it. The right side does not divide at all nicely into the left side. Did you overlook the exponents inside the parens or am I missing something?
Likes WWGD
BvU said:
Homework Statement: Solve ##x## from $$\left ( a+x\right )^{2\over 3} + 6\left ( a-x\right )^{2\over 3} =5\left ( a^2- x^2 \right )^{1\over 3} $$
Relevant Equations: actually, my algebra appears insufficient :frown:
I think this should work:
Let ##p = (a+x)^{\frac 13}## and ##q = (a-x)^{\frac 13}##.
The given equation can then be written as ##p^2 + 6q^2 =5pq##.
##p^2 - 5pq + 6q^2 =0##
##(p - 2q)(p - 3q) = 0##
And take it from there.
Edit: Spoiler removed.
Likes Math100, chwala, tech99 and 8 others
I should have seen it ... but didn't :cry: : the quadratic equation is mischieviously wrapped up in that kind of exam question.
@phinds : divide by ##(a-x)^{1\over 3} \ (a+x)^{1\over 3}## to get ## y+{6\over y} =5 ##
Likes chwala, Frabjous and phinds
As soon as I appreciated that $$(a+x)(a-x)=(a^2-x^2)$$ I was home free on this one
Likes chwala and PhDeezNutz
Worse comes to worse, time is running out on the exam, cube both sides. Only one term will remain to a non-unity power p/q. Leave it alone in one side and raise both sides to the qth power. Hardly elegant, but at least you'll get some credit.
Edit: In this exercise, you first cube both sides, end up with a mixed term; then isolate it on one side, then cube both sides again.
Likes chwala
WWGD said:
Worse comes to worse, time is running out ...
:smile: It's an exam from 1886
  • Haha
Likes nuuskur, hutchphd and WWGD
It's likely too late for you to get any credit for it now. :smile:
  • Haha
Likes chwala, PhDeezNutz, berkeman and 3 others
But it was an _open_ exam. ;).
  • Haha
Likes hutchphd
Likes WWGD
There you see how much the level of high-school math has declined nowadays! SCNR.
  • Care
Likes malawi_glenn, dextercioby and MatinSAR
I don't know, whether it's about IQ. It's rather about quality of high-school education. A colleague just told me in his last problem session a 4th semester (sic!) physics student was utmost lost at the task to do an integral by partial integration.
  • Wow
Likes malawi_glenn
or this
The first expression is nonsensical. Of course I mean the second.
It may be worth noting that the term ‘partial integration’ has two (that I know of) different meanings:
1) It is an alternative (though not widely used) name for ‘integration by parts’.
2) It is a term (informally?) used in multivariate calculus for integration with respect to a single variable. For example in https://www.cliffsnotes.com/study-guides/differential-equations/review-and-introduction/partial-integration the author writes ##f(x,y) = \int M(x,y)∂x## (which is consistent with @lurflurf's 1st example in Post #15). Though I don't know if this notational use of ##∂x## is widely accepted.
Likes lurflurf
or this
I thought partial integration and integration by parts mean two different things...correct me if i am wrong...i think partial implies to for e.g decomposing
##\dfrac{ax+c}{ax^2+bx+c}## into ##\dfrac{A}{(ax+b)} +\dfrac{B}{(cx+d)} ## where ##x## is a given variable and the rest are constants.
...then applying integration accordingly.
It would be interesting if i can get a different approach to this problem...i will check it out. I guess Binomial Theorem could apply though tedious.
Ok i am thinking along the lines of:
##\dfrac{(a+x)^\frac{2}{3}}{(a+x)^\frac{1}{3}}= 5(a-x)^\frac{1}{3} - 6(a-x)^\frac{2}{3}####(a+x)^\frac{1}{3}=5(a-x)^\frac{1}{3} - 6(a-x)^\frac{2}{3}####\dfrac {(a-x)^\frac{1}{3}[5-6(a-x)^\frac{1}{3}] }{(a+x)^\frac{1}{3}}=1##
Let
##a-x=k##
##a+x=m##
Then using the above... we shall get:
##6k^\frac{2}{3}-5k^\frac{1}{3}+1=0##
and
##m^\frac{1}{3}=1##
Let
##n=k^\frac{1}{3}##
then we shall have:
##6n^2-5n+1=0##
##n_1=0.5 ⇒k_1=0.125##
##n_2=0.333⇒k_2=0.037##
We know that
##m=1##
using, ##k=0.125## we shall have,
##a-x=0.125##
##a+x=1##
solving the simultaneous equation yields,
##-2x=-0.875##
##x=0.4375##
##⇒a=0.5625##
I hope I am not too late, but I have found the answers you put for ##x## but not sure why ##a## should be greater or less than zero, as you say in your first post (#1 up).
I hope this is readable.
Can anyone tell me please why should ##a\ge 0##? And if am mistaken in my work up there 👆?
What do you get if ##a = -1 ## ?
check
And high school curriculum didn't include complex numbers
It looks like you intended to divide both sides buy ##(a+x)^\frac{1}{3}## but you neglected dividing ##5(a-x)^\frac{1}{3}## by ##(a+x)^\frac{1}{3}## .
...I will check this again...
This
Let
##a-x=k##
##a+x=m##
and
##m^\frac{1}{3}=1##
Let
##n=k^\frac{1}{3}##
then we shall have:
##6n^2-5n+1=0##
We know that
##m=1##
##a-x=0.125##
##a+x=1##
##-2x=-0.875##
##x=0.4375##
##⇒a=0.5625##
This may be unorthodox approach but hey let us do it!
We have,
##(a+x)^{\frac{2}{3}} + 6 (a-x)^{\frac{2}{3}}=5(a^2-x^2)^{\frac{1}{3}}##
I will still let
##m=a+x##
and
##k=a-x##
then,
##m^{\frac{2}{3}} + 6k^{\frac{2}{3}}=5m^{\frac{1}{3}}k^{\frac{1}{3}}##
##6k^{\frac{2}{3}}=m^{\frac{1}{3}}[5k^{\frac{1}{3}}-m^{\frac{1}{3}}]##
Let
##m^{\frac{1}{3}}=1##
then,
##6k^{\frac{2}{3}}-5k^{\frac{1}{3}}+1=0##
the other steps to solution shall remain as shown on the quoted post.
cheers!
chwala said:
ThisThis may be unorthodox approach but hey let us do it!
We have,
I will still let
##m=a+x##
and
##k=a-x##
then,
Let
then,
cheers!
Why define m1/3=1?
Frabjous said:
Why define m1/3=1?
If you look at the solution, one variable, that is ##x## is dependant on the other variable ##a##...I can therefore choose to let my variable be equal to a certain value. The intention being to find any possible means to solve the equation (in my case using quadratic method).
Or is my thinking not correct?
Based on @vanhees71's subsequent response, he evidently meant "integration by parts." It's possible that he conflated the names of the techniques of integration by parts and integration by partial fraction decomposition.
Likes chwala
a is a constant and you were asked to solve for x(a).
You’ve added an equation, so you are solving for an intersection.
Likes SammyS
@Frabjous that is true, I added an equation which led me to the final solution in terms of ##a## and ##x##. Check my post ##19## that has the continuation after i came up with the quadratic equation.
chwala said:
@Frabjous that is true, I added an equation which led me to the final solution. Check my post ##19## that has the continuation after i came up with the quadratic equation.
So what? You get one value of x for one value of a. The OP has the solution which has TWO values of x for a given value of a. The OP also has the solution for other values of a. You are missing a lot of solutions.
  • #31
I will check if I can get other values by changing my ##m## value. Cheers man!
  • #32
You are going to come up with a finite number number ‘n‘ of solutions. Given that there are an infinite number of solutions, your grade for the problem will be n/∞=0. :wink:
Likes chwala
  • #33
@chwala ,
Your response to my post (#22), although I made a mistake in that post of mine. It is corrected here:
SammyS said:
(My post (#22) in reference to your post (#19) )
Correction:
... you neglected to divide ##6(a-x)^\frac{2}{3}## by ##(a+x)^\frac{1}{3}## .
Your post(#23)
We have,
I will still let
##m=a+x##
and
##k=a-x##
then,
(I'll cut in here.)
This looks fine. In fact you could write that as;
##\displaystyle m^{\frac{2}{3}} -5m^{\frac{1}{3}}k^{\frac{1}{3}}+ 6k^{\frac{2}{3}}=0## ,
which can be factored quite nicely, by the way.
You then go on to state;
Let
then,
cheers!
Although you get the same quadratic equation as you did in the "quoted post" (#19), that is only due to the choice of ##m=1##.
For other values of ##m##, posts 19 and 22 will not agree.
Likes chwala
  • #34
SammyS said:
@chwala ,
Your response to my post (#22), although I made a mistake in that post of mine. It is corrected here:Your post(#23)
(I'll cut in here.)
Thanks can see that we end up with what was previously found by other members:
... i.e
##x^2-5xy+6y^2=0##
##(x-2y)(x-3y)=0##
where;
##x=m^\frac{1}{3}##
and
##y=k^\frac{1}{3}##
Likes SammyS
  • #35
I think it's a "Germanism", because in German we call this technique "partielle Integration". Obviously in English it's exclusively called "integration by parts".
Likes hutchphd and chwala
FAQ: How Did 1886 Dutch Students Solve This Complex Math Problem?
What was the complex math problem that the 1886 Dutch students solved?
The complex math problem that the 1886 Dutch students solved was related to a challenging geometry or algebraic problem that required advanced mathematical techniques for that time. The exact details of the problem may vary, but it typically involved intricate calculations or innovative approaches to reach a solution.
How did the students approach solving the problem?
The students approached solving the problem by employing a combination of logical reasoning, mathematical principles, and possibly collaborative efforts. They likely used the mathematical knowledge available at the time, including algebra, geometry, and calculus, to devise a solution. Their approach would have involved breaking down the problem into smaller, more manageable parts and systematically solving each part.
What tools or resources did the students use to solve the problem?
The students in 1886 would have used the mathematical tools and resources available at the time, such as paper, pencils, compasses, and possibly early mechanical calculators. They also relied heavily on their foundational knowledge of mathematics, textbooks, and potentially guidance from their instructors or mathematical journals of the era.
Why is the solution by the 1886 Dutch students considered significant?
The solution by the 1886 Dutch students is considered significant because it demonstrated a high level of mathematical understanding and problem-solving skills for that period. It also highlighted the quality of mathematical education and the intellectual capabilities of students in the Netherlands at the time. Their solution may have contributed to further advancements in the field of mathematics.
Are there any modern implications or applications of the solution found by the 1886 Dutch students?
While the specific problem solved by the 1886 Dutch students may not have direct modern applications, the methods and principles they used can still be relevant. Understanding historical mathematical solutions can provide insights into the development of mathematical thought and inspire contemporary problem-solving techniques. Additionally, studying such historical problems can enhance our appreciation of the evolution of mathematical education and knowledge.
9K
