Baire Category Theorem .... Stromberg, Theorem 3.55 .... ....
  • MHB
  • Thread starter Math Amateur
  • Tags
    Theorem
In summary: A_1^{ - }$ ...... ... because ... $B_{ r_1 } ( x_1 ) \subset B_{ 2r_1 } ( x_1 )$ ... ... and so $B_{ r_1 } ( x_1 )$ is contained in $V\setminus A_1^{ - }$ ...Is that right?In summary, in the proof of Theorem 3.55 in Karl R. Stromberg's book "An Introduction to Classical Real Analysis", the author uses the fact that $V\setminus A_1^-$ is not empty to choose a point $x_1$ in $V\setminus A_1^-$. Then, by
Math Amateur
MHB
3,998
48
I am reading Karl R. Stromberg's book: "An Introduction to Classical Real Analysis". ... ...
I am focused on Chapter 3: Limits and Continuity ... ...
I need help in order to fully understand the proof of Theorem 3.55 on page 110 ... ... Theorem 3.55 and its proof read as follows:
At the start of the second paragraph of the above proof by Stromberg we read the following:
" ... ...Since \(\displaystyle A_1^{ - \ \circ } = \emptyset\), we can choose \(\displaystyle x_1\) in the open set \(\displaystyle V\) \ \(\displaystyle A_1^{ - }\) and then we can choose \(\displaystyle 0 \lt r_1 \lt 1\) such that \(\displaystyle B_{ r_1 } ( x_1 )^{ - } \subset V\) \ \(\displaystyle A_1^{ - }\) [ check that \(\displaystyle B_r (x)^{ - } \subset B_{ 2r } (x) \) ] ... ...My questions are as follows:Question 1
Can someone explain and demonstrate why/how it is that \(\displaystyle A_1^{ - \ \circ } = \emptyset\) means that we can choose \(\displaystyle x_1\) in the open set \(\displaystyle V\) \ \(\displaystyle A_1^{ - }\) ... how are we (rigorously) sure this is true ... ?
Question 2
How/why can we choose \(\displaystyle 0 \lt r_1 \lt 1\) such that \(\displaystyle B_{ r_1 } ( x_1 )^{ - } \subset V\) \ \(\displaystyle A_1^{ - }\) ... ?
... and why are we checking that \(\displaystyle B_r (x)^{ - } \subset B_{ 2r } (x)\) ... ... ?
*** EDIT ***
My thoughts on Question 2 ...
Since \(\displaystyle V\) \ \(\displaystyle A_1^{ - }\) is open ... \(\displaystyle \exists \ r_1\) such that \(\displaystyle B_{ r_1 } ( x_1 ) \subset V\) \ \(\displaystyle A_1^{ - }\) ...
... BUT ... how do we formally and rigorously show that ...
... we can choose an \(\displaystyle r_1\) such that the closure of \(\displaystyle B_{ r_1 } ( x_1 )\) is a subset of \(\displaystyle V\) \ \(\displaystyle A_1^{ - }\) ...
... (intuitively I think we just choose \(\displaystyle r_1\) somewhat smaller yet ...)
... and further why is Stromberg talking about \(\displaystyle r_1\) between \(\displaystyle 0\) and \(\displaystyle 1\) ...?
Help will be much appreciated ...
Peter
The definitions of nowhere dense, first and second category and residual are relevant ... so I am providing Stromberg's definitions ... as follows:
Stromberg's terminology and notation associated with the basic notions of topological spaces are relevant to the above post ... so I am providing the text of the same ... as follows:
View attachment 9167Hope that helps ...
Peter
  • Stromberg -  Defn 3.53 ... Nowhere Dense ...First and Second Category ... .png
Peter said:
Question 1
If $V\setminus A_1^-$ is empty then $V\subseteq A_1^{-\mathrm o}$, contradicting the fact that $A_1^{-\mathrm o}$ is empty. Therefore $V\setminus A_1^-$ is not empty and so it contains some point, which we can choose as $x_1$.
Peter said:
Question 2
*** EDIT ***
Your thoughts on Question 2 are quite correct. If you can choose a number, say $s$ such that $B_{ s } ( x_1 ) \subset V\setminus A_1^{ - }$, then let $r_1 = \frac12s$. Then $s=2r_1$, so that $B_{ 2r_1 } ( x_1 ) \subset V\setminus A_1^{ - }$ and hence the closure of $B_{ r_1 } ( x_1 )$ is contained in $V\setminus A_1^{ - }$.
Given $r_1$ with that property, any smaller (positive) value of $r_1$ will have the same property. So you can always assume that $0<r_1<1$. Stromberg's reason for wanting that is that this is the first step of an inductive construction in which he wants to ensure that $r_n\to0$ as $n\to\infty$. The easiest way to do that is to require that $r_n<1/n$.
Thanks Opalg ...
... very much appreciate your help...
Peter
Peter said:
Thanks Opalg ...
Peter
Hi Opalg ...
Thanks again for your help ...
Just a further point of clarification ...
You write:
" ... ... Then $s=2r_1$, so that $B_{ 2r_1 } ( x_1 ) \subset V\setminus A_1^{ - }$ and hence the closure of $B_{ r_1 } ( x_1 )$ is contained in $V\setminus A_1^{ - }$. ... ... "So ... as I understand it, you are arguing that because $B_{ 2r_1 } ( x_1 ) \subset V\setminus A_1^{ - }$ ...
... ... that therefore ... the closure of $B_{ r_1 } ( x_1 )$ is contained in $V\setminus A_1^{ - }$. ...
... that is that $B_{ r_1 } ( x_1 )^{ - } \subset V\setminus A_1^{ - } $ ... ...
But why ... rigorously ... is this true ... (... it certainly seems plausible ... but rigorously ...? )
Hope that you can help further ...
Peter
The result that you need is that if $x$ is an element in a metric space $(X,d)$, and $r>0$, then $B_r(x)^- \subseteq B_{2r}(x)$.
To see that, notice that if $y\in B_r(x)^-$ then there must be a point $z\in B_r(x)$ with $d(z,y)<r$. By the triangle inequality, $d(y,x) \leqslant d(y,z) + d(z,x) < r + r = 2r$. Therefore $y\in B_{2r}(x).$
Thanks for the help Opalg ...
But ... just a point of clarification ...
You write:
" ... ... notice that if $y\in B_r(x)^-$ then there must be a point $z\in B_r(x)$ with $d(z,y)<r$ ... ... "I can see what you write must be true (by definition) when \(\displaystyle y\) is a limit point of \(\displaystyle B_r(x)^-\) ... by why is this true when \(\displaystyle y\) is an interior point of \(\displaystyle B_r(x)^-\) ... given we are dealing with a general metric space ...
Hope you can help further ...
Peter
Peter said:
You write:
If \(\displaystyle y\in B_r(x)^-\) is not a limit point, then \(\displaystyle y\in B_r(x)\), which is obviously contained in \(\displaystyle B_{2r}(x)\).
Thanks for all your help, Opalg ...
It is much appreciated ...
Peter
Related to Baire Category Theorem .... Stromberg, Theorem 3.55 .... ....
1. What is the Baire Category Theorem?
The Baire Category Theorem is a fundamental result in topology that states that in a complete metric space, the intersection of countably many dense open sets is also dense. This has important implications in the study of topological spaces and their properties.
2. Who discovered the Baire Category Theorem?
The Baire Category Theorem was first proven by French mathematician René-Louis Baire in 1899. However, it was not widely recognized until the work of Polish mathematician Stefan Banach in the 1920s.
3. What is the significance of the Baire Category Theorem?
The Baire Category Theorem is a powerful tool in the study of topological spaces and their properties. It allows for the construction of interesting examples and counterexamples, and is used in many areas of mathematics, including functional analysis, measure theory, and differential equations.
4. What is Stromberg's Theorem 3.55?
Stromberg's Theorem 3.55 is a generalization of the Baire Category Theorem that applies to locally compact Hausdorff spaces. It states that in such spaces, the intersection of countably many dense open sets is still dense. This result has important applications in functional analysis and harmonic analysis.
5. How is the Baire Category Theorem used in mathematics?
The Baire Category Theorem is used in many areas of mathematics, including functional analysis, measure theory, and differential equations. It is also a key tool in the study of topological spaces and their properties. Additionally, it has applications in other fields such as physics, computer science, and economics.
  • Topology and Analysis
