Balancing a 3d weight vs lift system
The discussion focuses on balancing a 3D system with fixed weights and variable lift forces, specifically addressing how to achieve stability and control movement without unwanted rotation. Key points include the necessity of ensuring that the sum of forces and torques equals zero to maintain balance, along with the equations governing translational and rotational movements. The user is struggling with torque calculations, particularly in accounting for Y-axis rotation when attempting to move along the X-axis, leading to instability in their simulation. Suggestions indicate that additional points of support may be required for pure movement without rotation. The user is seeking clarity on combining torque calculations to achieve a comprehensive understanding of the system's dynamics.
LordSimpson
Hi I'm trying to balance any 3d system with various fixed weights by selecting the correct lift forces for points of lift an example system would be the following shape ( view from above , think a plane missing the right wing) where X is a point of weight and L is a lift point (also has weight)
[X1][X2][L1][X4][L2]
[X3]​
[L3]​
to be clear
X’s are fixed weights
L’s can have variable lift forces
L3 needs to counteract the rotation from its own weight and the weight of X3
L1 is mostly central along the main body so will can counter X1,2,4 and L2's weight
L2 may not be needed
so something like L3 = 2(cancelling its and X3 weight / moment), L1 = 5 (cancelling the main body’s weight) L2 = 0 else it would flip
This is just an arbitrary shape, I need to be able to solve it for any number of lifts / weights in any shape / positions.
I’m sure I learned how to solve this sort of problem during my degree however I guess I can’t find the correct set of words to put into the all-knowing google!
Any help would be appreciated!
You can get 6 conditions for balance:
- the sum of all forces has to be 0 (otherwise the object would accelerate). This gives 3 equations, one for each dimension
- the sum of all torques has to be 0 (otherwise the object would rotate). Again, you get one equation per dimension. It does not matter which point you use as center of your coordinate system, as the conditions above make sure that you get the same result everywhere.
Any combination of lift forces which satisfies those conditions is fine. If all forces are vertical, you can reduce the system to 3 equations (one for the horizontal position and two for rotations).
Thanks :D, Realised the goggle phrase i was missing was 'Linear Equations'
I've now got most of the equations worked out but currently can't get it to work quite right hopefully someone will see where I've messed up. Currently I have a problem where when I'm attempting to move the object in the X axis it will rotate around the Y axis as-well.
I'm Achieving the X axis movement by rotating the lift objects about the Z axis causing the force to change form completely down (0.0,-1,0.0) to slightly to the left or right (0.7,-0.7,0.0).
For the Translational equations I have the following
Where F is a vector for the force direction.
F1.y + F2.y ... +Fn.y = Weight
F1.x +... = Xaxis movement (left right)
F1.z +... = Zaxis movement (forward back)
then the rotational equations
Where T = the torque calculated by r cross F, where r is a vector from the centre of mass to the location of F (Centre Of Mass - Location of F)
giving me
T1.x + T2.x ...+ Tn.x = Current Torque about X axis (pitch)
T1.y + T2.y ...+ Tn.y = Current Torque about Y axis (yaw)
T1.z + T2.z ...+ Tn.z = Current Torque about Z axis (roll)
I'm calculating the Current Torque by finding the amount of torque necessary to move the objects Up direction vector to straight up (0,1,0).
Any ideas where I may have gone wrong?
I have a feeling its the torque calculation as the this torque calculation doesn't include any Y axis rotation, I assume i have to calculate the torque required using the froward vector (and right ? ) however I am unsure how i should combine them to get the total torque required for each rotational axis.
I don't see your problem at the moment.
If you cannot avoid this... well, then you'll need more points of support to get a pure movement.
Torque around the Y axis will give a rotation around the Y axis.
Which "forward vector"?
Ok the extra supports helped, however I'm definitely missing something as the simulation I've built is less than completely stable.
Ok hopefully this will make the torque bit a little clearer. Currently I'm calculating the torque required to rotate the object from one vector direction to another. This means I can't get a full picture of the torque from one calculation, For example, If I calculate the torque required to rotate from the objects up direction to straight up (to make the object level) I will only get information about the X and Z axis as there is no way of telling what the Y axis rotation is. A vector can't tell you the rotation about its self, but it can tell you the rotation about its two orthogonal counterparts (forward and right).
So I'm unsure how to get the complete picture of the torque.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
