Balancing area of a loop and magnetic field through it
It is possible to change both the area of a loop and the magnetic field passing through it without inducing an emf, provided the changes maintain a constant magnetic flux. The equation for magnetic flux, Φ = BA, demonstrates that if the magnetic field strength is halved while the area is doubled, the overall magnetic flux remains unchanged. This means that although the individual components change, the net effect on the induced emf can be zero if the changes occur simultaneously. Therefore, even with alterations to both parameters, the induced emf remains constant, resulting in no net change. The discussion confirms that the induced emf can be zero under specific conditions of simultaneous change in area and magnetic field.
uzair_ha91
Question: Is it possible to change both the area of the loop and the magnetic field passing through the loop and still not have an induced emf in the loop?
Equation: change in Magnetic flux= area * magnetic flux density
My attempt: If the magnitude of magnetic field is changing, then by either increasing or decreasing the area of the loop, the change in magnetic flux associated with the loop can be kept constant. Then the induced emf will be zero.
Can you somehow prove this through the equation, numbers? Would appreciate the help.
Φ=BA
Say initially you have Φ0=B0A0. Then decrease B0 by 1/2 (so B1=1/2B0) and you increase the area by a factor of 2 (A1=2A0)
Φ1=B1A1 =(1/2 B0 *2A0)=B0A00
if the changes occur in the same time interval,t, then E0=E1
Once there is a change in magnetic flux, there will be an emf induced. So as much as I can say, even if you decrease one and increase the other and emf is still being induced, it just has the same value as before. So the net emf induced would be zero.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
