Balancing Reaction of Formic Acid and Ammonium Hydroxide
  • Thread starter Thread starter PCSL
    Acid Reaction
The chemical reaction between 1 mole of ammonia (NH3) and 0.1 mole of formic acid (HCO2H) produces ammonium formate (NH4HCO2) without generating water. The balanced equation is NH3 + HCOOH → HCOONH4. In this reaction, there is a 1:1 mole ratio, and since only 0.1 mole of formic acid is present, 0.9 moles of ammonia remain unreacted. It's important to note that when writing balanced equations, only stoichiometric coefficients should be used, not specific mole quantities.
PCSL
I'd like to write the chemical equation for the reaction of 1 mole of ammonium hydroxide with .1 mole of formic acid. I understand that NH4OH is not ammonium hydroxide, and it is more accurate to write NH3, implying NH3 (ammonia) + HCO2H (formic acid) --> NH4HCO2 (ammonium formate) but would there also be water produced from the reaction? Also this reaction has a 1:1 mole ratio for the ammonia and formic acid so would I also add a term on the right for excess ammonia that does not react? Thanks for the help - I haven't had a chemistry course in years.
Chemistry news on Phys.org
That's a reasonably correct depiction of what is happening. There is no water produced.
No. Google limiting reagent.
Perfect - so I could just write NH3+.1*HCO2H --> .1NH4HCO2 with .9 moles of ammonia in excess? Thanks.
Not exactly. You don't use numbers of moles in the balanced reaction - only stoichiometric coefficients. So your reaction, when balanced, should look like
(I am used to a bit different convention for writing carboxylic acids and their salts, nothing wrong with the one you use though).
And then you can describe what is happening in your particular case. Eons ago I was trained to write it below the reaction equation (but formatting such things these days is getting ridiculously time consuming).
And yes, there is 0.9 moles of the ammonia left after the reaction.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
