Ball dropping and frame of reference
In summary, the conversation discusses the concept of gravity and the motion of objects in a moving train. The question is raised as to why a ball, released from inside a moving train, falls straight down instead of falling behind the train due to its forward momentum. The answer is explained from both the train frame and the Earth frame, where the key concept is the independence between horizontal and vertical motions. The conversation also touches on the concept of relative velocity and the parabolic path of a falling object.
werunom
29
Consider I am in the train with a ball traveling at normal speed of a train. I drop the ball, it follows a straight path of descent and falls in front of my feet.
For an observer on the platform, the ball follows a parabolic path and falls in front of my feet.
(Please go to this http://www.phys.unsw.edu.au/einsteinlight/jw/module1_Galileo_and_Newton.htm" and play the flash. It is similar to the setup I have mentioned above)
The doubt -
The moment I, standing on the train, release the ball, the ball is in free space. And the only force acting on it is gravitational. Then why doesn't it fall straight with respect to the Earth [as that is the one which is pulling it] from the position in space it is released? That is, when the ball is released, it should fall few meters behind my feet as I would have moved with the train; whereas the ball was in free space.
I know that the above description is a fact. But I just don't know why. Please do explain the reason.
I think it is the same thing when we get down from a bus which is motion with respect to the road - you experience a force which pushes you for few meters and then you come to a halt on the road. Am I correct?
You are correct at the end of your post. The ball when released has forward momentum. It keeps that as it falls.
Think of it this way: if your train is in space away from gravity and you let go of the ball does it stop or stay next to your hand?
Adding gravity acting perpendicularly to your line of motion won't change that.
What may change is the measured value of the gravity in the train. Is it still 9.8 m/ss?
Thanks for answering.
But my question was with respect to the train reference frame and you answered for platform frame.
From the platform's observer [Op] point of view, the train, the observer [Ot] inside that with the ball, all have relative velocity and thus a momentum. So because of which, the Op would observe that the ball would have momentum and gradual loose it, thus having a parabolic path.
But I am asking the question from Ot point of view. If Ot releases the ball, the ball is in the free space.
And from this point, I am completely confused. because, if it is free space, just being released from the clutches of Ot, then it should have the same parabolic path [of gradual losing of momentum] as it is NO more in contact with a body (either train or Ot) which is traveling with some velocity.
But at the same time, I know that the ball doesn't have relative velocity with the Ot or train.
I cannot pinpoint which point in the above thought flow is the wrong one. Please clarify.
Compare the above scenario of leaving the ball inside the train to one exactly opposite - of leaving the ball outside the train. That is, Ot is standing near the edge of bogie [or a hand outside the window of the train] and releases the ball. Then in this case, the ball will have a parabolic path.
What is the difference between the two points in space - one being inside the train where the ball was released and the other being outside where the ball was released?
And regarding your statement "if your train is in space away from gravity and you let go of the ball does it stop or stay next to your hand?" - my answer would be that it gradually comes to halt. Am i correct in this?
In the train frame, every body moves with same velocity in forward direction. As the relative velocity among the man, train, ball is zero before releasing, they appear to be at rest w.r.t each other. When the ball is just released, it continues to possesses the forward velocity, which doesn't sees any resistance in the horizontal direction. Due to this undiminishing horizontal velocity, it is still at relative rest in the horizontal direction. But, due to force of gravity it falls down.
(Obsrvr moving fwd with const v + ball moving fwd with const v + falling downward with const g) = falling downward with const g i.e first two terms cancel each other's effect leaving the last.
In the Earth frame, when the ball is seen to be released, it possesses the same forward velocity as in the above case, which also doesn't sees any resistance in the horizontal direction. As the observer is at rest here, the ball is not at relative rest in the horizontal direction- it carries on forward with the velocity it possessed when it was in the train-man's hand.
(Obsrvr at rest + ball moving fwd with const v + falling downward with const g) = falling downward with parabolic trajectory.
There's no gradual loss of horizontal momentum as you are thinking of. The key concept is the independence between horizontal and vertical motions. The superposition of an horizontal arithmetic sequence with an independent vertical geometric sequence produces a parabola - Thats the beauty!
Thanks for the answer superkan619.
It helped!
FAQ: Ball dropping and frame of reference
What is the concept of "ball dropping" in physics?
"Ball dropping" is a common experiment used in physics to demonstrate the effects of gravity on an object. It involves dropping a ball from a certain height and measuring the time it takes for the ball to reach the ground. This experiment helps us understand the relationship between distance, time, and acceleration due to gravity.
How does frame of reference affect the observation of a ball dropping?
Frame of reference refers to the point from which an observer is viewing an event or object. In the case of a ball dropping, the frame of reference can affect the perception of the motion and speed of the ball. For example, a person standing on the ground may observe the ball dropping straight down, while someone on a moving train may see the ball appear to move at an angle due to their frame of reference.
What is the difference between an inertial and non-inertial frame of reference?
An inertial frame of reference is one in which Newton's laws of motion hold true, meaning that objects will remain in a state of rest or constant motion unless acted upon by an external force. A non-inertial frame of reference is one in which Newton's laws do not hold true, such as a rotating frame of reference.
How does the force of air resistance affect the motion of a falling ball?
The force of air resistance, also known as drag, acts in the opposite direction of the ball's motion and increases as the ball's speed increases. This force can slow down the ball's descent and lead to a different trajectory than if there was no air resistance. The amount of air resistance also depends on the shape and size of the ball.
Can the mass or weight of a ball affect its rate of descent?
According to the laws of gravity, the mass or weight of an object does not affect its rate of descent. This means that a heavier ball and a lighter ball will fall at the same rate if dropped from the same height. However, air resistance may have a greater effect on a larger or more massive ball, causing it to fall at a slower rate.
10K
