Ball falls from top of cliff; kinematics
  • Thread starter Thread starter dansunefusee
    Ball Kinematics
A ball is dropped from a 17.4 m cliff while a second ball is thrown upward with an initial speed equal to the final speed of the first ball upon impact. The final speed of the first ball is calculated to be approximately 18.47 m/s. To find the point where the two balls cross paths, the equations of motion for both balls must be combined. The first equation describes the distance fallen by the first ball, while the second accounts for the height of the cliff and the upward motion of the second ball. Correct manipulation of these equations will yield the time and distance at which the balls meet.
dansunefusee
A ball is dropped from rest from the top of a cliff that is 17.4 m high. From ground level, a second ball is thrown straight upward at the same instant that the first ball is dropped. The initial speed of the second ball is exactly the same as that with which the first ball eventually hits the ground. In the absence of air resistance, the motions of the balls are just the reverse of each other. Determine how far below the top of the cliff the balls cross paths.
Ball 1:
u1 (initial velocity)= 0 m/s
g= -9.81 m/s2
H (height of cliff)= -17.4m
V1 (final velocity)= ?
Ball 2:
u2= V1= ?
Unknowns:
t= ?
x (where balls meet above the ground)= ?
V2=u2 + 2ax
x = u(t) + 0.5(g)(t)2
First, I calculated the final velocity (V1) of Ball 1 as so:
V12=u2 + 2ax
V1= sqrt[(0m/s)2 + 2(-9.81m/s2)(-17.4m)
V1= 18.4673m/s ~18.47m/s
Therefore, the u2 (initial velocity) of Ball 2 is also 18.47m/s.
I know that the next step is to calculate the time by using x = u(t) + 0.5(g)(t)2, but I'm not sure on how to manipulate the equation to fit the criteria of this problem. Please help me!
Hi dansunefusee. welcome to PF.
Both the balls start simultaneously. When they meet they must have traveled same duration t s. If x is the distance from the top of the cliff, then for the falling ball
-x = -1/2*g*t^2...(1)
For the ball going up
h - x = ut - 1/2*g*t^2 ...(2)
Where h is the height of the cliff. Solve the two equations and find the time t.
Thank you! :) I'll need all the help I can get from PF this year. Haha.
To make sure I am doing this right, I would need to combine the 2 equations just to find time?
Given equations:
1) -x = -1/2*g*t^2
2) h - x = ut - 1/2*g*t^2
Therefore, I would plug the 1st equation for the -x variable in the 2nd equation to get:
h - (-1/2*g*t2) = ut - 1/2*g*t2
Then isolate the time (t) variable by itself?
:confused:
Hey , after you take the time(t) , substitute it to (1) equation , then x will come,
Given equations:
1) -x = -1/2*g*t^2
:confused:
This step is wrong.
It should be h - 1/2*g*t2 = ut - 1/2*g*t2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
