Baseball dropped from building with air resistance
The discussion revolves around calculating the energy dynamics of a baseball dropped from the Empire State Building, focusing on potential energy, kinetic energy, and energy dissipated by air resistance. The initial potential energy was calculated to be 541 J, but confusion arose regarding the final kinetic energy and the effects of air resistance. The participant struggled with the integration process to find the final velocity, leading to discrepancies between their results and the textbook answer of 87 J for kinetic energy. Clarification was provided on the direction of forces, with a consensus that drag acts opposite to gravity, which was initially misunderstood. Ultimately, it was confirmed that the quadratic term for air resistance should be used for accurate calculations.
deekin
A baseball (radius = 0.0366m, mass = 0.145kg) is dropped from rest at the top of the Empire State Building (height = 1250ft = 381m). Calculate (a) the initial potential energy of the baseball, (b) its final kinetic energy, and (c) the total energy dissipated by the falling baseball by computing the line integral of the force of air resistance along the baseball's total distance of fall. Compare this last result to the difference between the baseball's initial potential energy and its final kinetic energy.
F = ma = -mg -cv
P.E.=mgh
c=1.1346\cdot 10^{-5}
For part a, it was easy to find the potential energy.
mgh = (0.145kg)(9.8m/s2)(381m) = 541 J
Part b is where I am stuck. I took down to be negative. For the force, we have
F = ma = -mg - cv
since I was told by the professor to use the linear term rather than quadratic. Then we have
ma=mv\frac{dv}{dx}=-mg-cv\Rightarrow \frac{mvdv}{-mg-cv}=dx
\Rightarrow \int \frac{mvdv}{-mg-cv}=\int dx
Where the limits of integration on the left are from v_0=0 to -v_f and the limits of integration on the right are from x_0=381m to x_f=0. We now have
\frac{-mv}{c}+\frac{m^2g\ln(mg+cv)}{c^2} evaluated using the bounds mentioned above, this is the left hand side. The right hand side is x_f-x_0=-381m.
Now we have
\frac{mv_f}{c}+\frac{m^2g\ln(mg-cv_f)}{c^2}-\frac{m^2g\ln(mg)}{c^2}=-381
I tried solving this numerically just using Maple, but the value I got for the final velocity does not make sense when I compare my answer for the final kinetic energy to the back of the book. The back of the book has the final kinetic energy as 87 J. Using the equation for kinetic energy
T=\frac{1}{2}mv^2
this means that the final velocity is 34, based on the final kinetic energy given in the back of the book. Which is far different from the final velocity of 86.39 that I get. Where am I going wrong?
Note: I have not tried to do part c yet, this is just focused on part b.
Is the drag force on the baseball acting in the same direction as the force due to gravity? According to your F = ma equation, the ball should fall faster with drag than without. Does that seem logical?
The drag acts in opposition to the velocity (always in opposition to the direction of movement), so it should be acting in the opposite direction to the force due to gravity. However, in lecture, as something is falling the professor put mg and cv to be negative. So I'm wasn't sure what to do.
Consider one of the directions to be positive. Let the downward direction be positive. mg acts downward and the resistive force upwards. Can you now apply F=ma?
Ah ok, thank you. For F = ma = mg - cv. However, I just got back from class and apparently he was mistaken, we were supposed to use the quadratic term for the air resistance rather than the linear. I've got it now, thanks again.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
