HCB
- 10
- 7
- TL;DR Summary
- I want to better understand the theoretical functioning of electrical capacitance. This is not about discrete electronic components.
Hello, all. First, I want to apologize if this is not the correct forum or area of the forum for this question. Please direct me if I should be posting this somewhere else.
I have some questions regarding what I believe is best described as the "theory" of electrical capacitance. As my questions are about what I believe are the physics involved, and not about electronic components, I felt that a physics forum was the place to ask.
My examples are intentionally simplistic as I wish to understand the fundamentals. This is not about a particular application.
It is my understanding of electrical capacitance that if two pieces of electrically-conductive material are connected to a DC power supply, one to the negative terminal and one to the positive terminal, that it is possible to imply a durable charge to the two pieces (leaving an electrical potential between them), even if the power supply is disconnected from them. For an example: if two pieces of identical volume and shape copper are placed on a non-conducting surface and surrounded by air and then connected to a 12 volt DC power supply, after the power supply is disconnected from them, they should still have a 12 volt potential between them. For this example, we'll say the two pieces are 1/2 inch apart. As 12 volts is insufficient to arc across 1/2 inch of air, and the surface the two pieces are sitting on is non-conductive, theoretically speaking, would the 12 volt potential exist indefinitely? If the two pieces are moved to 1/4 inch distance from one another and again connected to the 12 volt DC power supply, would this increase the effective capacitance between them? I *think* that as the two pieces are moved closer and closer to one another, the capacitance between them will increase so long as the electrons are not able to arc between them.
When connecting two conductive pieces to a 12 volt DC power supply, let's continue with copper as the material, I *think* it is the electrons flowing from the negative terminal of the power supply which saturate the conductive material connected to it. Is that correct? Furthermore, *think* it is the presence of those extra electrons in the negatively-charged material which repel electrons in the conductive material connected to the positive terminal. Is that correct?
If these two pieces are electrically charged by such connection to a DC power supply, one has excess electrons (negative charge) and one has had electrons driven from it by the repelling force of the negatively-charged piece (positive charge). Is that correct?
Now, if these two pieces are electrically charged thusly, does this impart any actual physical attraction between them? This is where things get murky for me the most: I recall from physics classes (and chemistry, I believe, too) from many years ago that "opposites attract", and I recall that some atoms are attracted to other atoms based on their dissimilar charges (if I recall correctly). So, too, molecules I *think*. In this example of two pieces of copper which have been electrically charged, one positive and one negative, will there be any physical force between them caused by their different polarity charges?
Continuing in that vein, if these same two pieces of copper are charged as mentioned above, will they have any effect on charged particles around them? For instance, if these two pieces are charged, will they physically attract or repel ions in the air?
I'm not sure I'm knowledgeable enough to ask coherent questions. My apologies if these are dumb questions.
Thank you for your time.
--HC
--HC
