Battery charging via Solar pannel
Charging a battery via a solar panel can yield good power conversion under varying irradiance levels due to the battery's ability to adjust its terminal voltage during charging. The solar panel must output a voltage higher than the battery's to initiate charging; otherwise, the battery may drain back through the circuit. Many users, particularly sailors, have experienced drained batteries due to improper installation of diodes or leaving solar chargers connected overnight. A simple control circuit with a PNP pass transistor can enhance efficiency compared to using a diode alone. Understanding these dynamics is crucial for optimizing solar charging systems.
rusty009
Hey guys, I recently conducted an experiment which involved charging a battery via a PV module and also logging the I and V values to calculate conversion efficiencies. I also logged the I and V values from two other circuits with a fixed resistance. I understand that every irradiation has a Maximum Power Point (MPPT) so a fixed resistance will never draw the maximum energy yield from the PV module. But when I saw the results I saw that the power conversion for the battery was good under high and low irradiances. My question is why is this? Does a battery have some sort of control circuit to vary its resistance ? Thanks in advance.
No, but depending on the battery type the terminal voltage and so the current availabel from the PV will change as it charges.
For everythign you want to know about batteries see here http://www.batteryuniversity.com/
I've looked through that but I still don't understand what is actually happening.
As long as the PV output voltage is higher than the battery it will charge the battery. When the PV output drops, the battery will drain through the PV circuit. Many sailors have woken up to find drained batteries from either leaving their solar charger on at night or not installing diodes to keep the current flowing only to the battery.
Are you certain that durring the low irradiance test the battery was not what you measured for power conversion?
The forward voltage drop of a diode is roughly 0.6 volts, and is roughly 3 times the emitter-collector drop of a saturated PNP transistor, so using a simple regulator comprised of a simple control circuit and a PNP pass transistor on the + side of the charging voltage is better.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
