Beam calculations - Simply supported vs pinned both sides
  • Thread starter Thread starter Turbine
    Beam Calculations
The discussion revolves around the classification of beam connections, specifically comparing simply supported beams and pinned connections without rollers. A pinned connection allows for rotation but does not permit horizontal translation, while a simply supported beam typically accommodates movement due to rollers. The participant is analyzing a horizontal steel beam pinned between two vertical beams for a hydraulic press application, seeking clarity on how to apply beam formulas accurately given the unique connection type. The conversation highlights the importance of understanding the limitations of textbook formulas when applied to real-world scenarios, particularly regarding deflection calculations. Ultimately, the participant is trying to reconcile the differences in support types to determine the appropriate approach for analyzing beam behavior under load.
Turbine
Hi guys,
Hopefully a fairly simple question. All beam formulas I've come across, whether in my own textbooks or Machinery's Handbook, have two sets of formulas for beams. One will be for "simply supported", where one end is pinned and the other end is a pin-roller. The other connection type is simply "fixed". Where would a beam connection fall among those which has ends that are both pinned without "rollers". Basically I'm analyzing a horizontal steel beam pinned between two vertical beams.
Example:
This very well is just a "simply supported" example, my only hesitation is knowing that there will be no horizontal translation in my design, whereas in traditionally "simply supported" situation, there is horiz. translation due to the the roller. Hopefully someone can set me straight. Thank you!
A pinned connection can take a load applied in any direction; a simple support can take a load only in one direction (usually vertical). The rollers on a simple support allow a beam to grow or shrink (usually due to temperature differences) without loading up in the axial direction (think of expansion joints in roads and bridges).
You diagram is not clear enough to determine if the horizontal beam is restrained against rotation at the ends or not. If the pins were actually bolts or rivets, you could make the case that this beam is fixed at each end.
Supports are generally idealized to allow for an analysis of some sort. Analyzing beams using actual support conditions and configurations is a little messier.
Thank you for the quick response. In the diagram, those "pins" are literally just that, about 1-1/4" diameter steel rods. The beam is about 48" long. Application is a hydraulic press. I could just as well design it with a pin support underneath one end of the beam to act as a roller, which would precisely fit the "simply supported" equations.
It's not clear how big a hydraulic press we are talking about here, nor how this structure goes with it. Using a single pin at each end of the horizontal beam may also not be advisable.
I will warn you that if you are not a mechanical engineer or a machine designer, you shouldn't be using formulas picked up out of a handbook unless you fully understand the limitations of their application.
The size isn't a factor in this question, simply trying to understand the differences in the called-out supports. As for press designs, a single pin connection is standard on many smaller H-frame presses (I'm looking at 40-tons or less). This allows for an adjustable lower platform. I am a returning student (former aviation professional), now a senior undergraduate mechanical engineering major. I'm doing this a an exercise in engineering to refresh on some of these topics. I've done plenty of shear/moment diagrams in years past, bending calculations, bearing stress, etc. But trying to apply textbook problems to real-world situations isn't as cut-and-dry. I'm still learning, by no means have I mastered the material (obviously), and I certainly appreciate your advice.
From my understanding, a fixed support resists any rotation at the support, in contrast to pinned connections that do allow rotation. The confusing difference is between pinned supports with rollers and without. A rollers allow translation along the x-axis, whereas a simply pinned connection does not, yet still allows rotation. Therefore the stress, I'd imagine, will be different, and this is precisely where I'm lacking clarity.
For example, looking at max deflection using my above drawn example. Given a single point load, deflections for two support instances are:
Supported at both ends: WL^3/48EI
Fixed at both ends: WL^3/192EI
(Source: Machinery's Handbook)
Clearly the fixed-support case will have the least deflection. But if the ends are pinned and can NOT translate along the x-axis (as I believe the "supported at both ends" case assumes can occur), yet the ends can rotate unlike fixed-ends, then the deflection would really be in between the two formulas. How does one account for that? Of course I could assume worst case (and perhaps that's what you do), but I'd imagine this has got to be a fairly standard case.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
