Bearing Failure in Motor-Driven Shaft with 40 kW Load
The discussion centers on a recurring bearing failure issue in a motor-driven shaft system under a 40 kW load. The setup includes a 1309 self-aligning ball bearing and a 2209 NUP bearing, both experiencing failures within 2 to 3 months of operation. Potential causes identified include excessive axial load on the self-aligning bearing, misalignment at the load end, and possible issues with belt tension or bearing selection. Recommendations include consulting a bearing specialist for failure analysis and considering the use of tapered bearings to better handle axial loads. Proper diagnosis requires a thorough examination of the entire setup and the failed bearings.
Koenigindia
I have a problem of bearing failure. A motor drives a shaft thro a flat belt. This shaft is connected to a load of around 40 kw. The shaft has 1309 self aligning ball bearing as floating bearing at the back end of shaft. On the load side there is a bearing 2209 NUP. The bearing inners are locked by circlips and outer is locked with housing. But within 2 to 3 months of continuous running, either the shaft shifts away from the load after abrading the circlip or the bearing 2209NUP fails. Will somebody be able to throw some light on what is wrong around here.
My recommendation would be to take or send the bearing and gearbox (or pictures) to a SKF dealer. The have people that do bearing failure analysis on bearings many times a day, and there is likely very little they have not seen.
It could be as simple as your belt being too tight, too much overhang or to the wrong bearing being used, all the way to improper design of gearbox.
SKF sells a failure analysis book for $5 plus other info here:
http://www.skf.com/portal/skf/home/aptitudexchange?contentId=0.237932.237933.237935.237962.238715
Do you have any kind of vibration monitoring on this set up? It sounds to me like your alignment at the load end may be off putting much more load on the bearing than should be. There is also the issue of imbalance that could be playing a part as well. I can keep guessing, but its a lost cause.
It is impossible to tell you exactly without being able to see the entire set up and what the bearing looks like after failure. Is there any discoloration on the bearing?
can u attach the sectional view of the bearing arrangement, so that i can analyse the bearing arrangement..
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
