MHB "Bearing" question - finding distance between two objects
  • Thread starter Thread starter tantrik
    Bearing
The discussion revolves around solving a trigonometry problem involving a motorboat's position relative to a lighthouse. The motorboat is initially 10 km south of the lighthouse and travels at a bearing of 53 degrees. The confusion arises regarding the interpretation of the boat's movement and its closest point to the lighthouse. To find this distance, a right triangle is formed, where the hypotenuse is 10 km, and the angle at the boat's position is 53 degrees. The sine function is suggested to calculate the shortest distance from the lighthouse to the boat's path.
tantrik
Dear friends,
I am having problem solving the following question related to "bearing" in trigonometry.
A motorboat is 10 km South of a lighthouse and is on a course of 053 degrees. What is the shortest distance between the motorboat and the lighthouse?
My confusion is how does a boat travel 10 km South of a lighthouse and making an angle of 53 degrees clockwise from North. Is there something wrong with the question itself?
Thanks in advance.
Mathematics news on Phys.org
I think the $10 \, \text{km}$ distance is the initial position of the motorboat. It'll travel in a direction $53^{\circ}$ clockwise of North, passing by the lighthouse. There will be one point in its travel where it will be the closest to the lighthouse. How far away is the lighthouse at that point?
Draw a line from the lighthouse "due south" to the present position of the ship. Draw the line showing the path of the ship. Finally, draw the line from the lighthouse perpendicular to the path of the ship. You now have a right triangle. The first line, "due south", is the hypotenuse and is 10km long. The two other lines are the legs of the right triangle. Since the path of the ship makes a 53 degree angle with north, the angle at the current position of the ship is 53 degrees.
So you have a right triangle with angle 53 degrees, the hypotenuse of length 10 and you want to find the length of the leg opposite that angle. Sounds like a sine!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
