- #36
bhobba
Mentor
- 10,796
- 3,665
Elroy said:Given this, I find it useful to think of superposition and entanglement as separate things.
There are standard definitions of superposition and entanglement in QM. I suggest you stick to those.
They are:
1. Superposition reflects the vector space structure of so called pure states. That is if you have a system that can be in state state |a> and state |b> then it can be in a superposition of those states ie c1*|a> + c2*|b> where c1 and c2 are complex numbers. This is called the principle of superposition and is a fundamental principle of QM. It is not an axiom because it follows from something else - but no need to go into that here.
2. Entanglement applies the principle of superposition to separate systems. Suppose you have a system that can be in state |a> or |b> and another system that also can be in state |a> or |b>. If system 1 is in state |a> and system 2 in state |b> that is written as |a>|b>. Conversely if system 1 is in state |b> and system 2 on state |a> that is written as state |b>|a>. But we can apply the principle of superposition to give a state c1*|a>|b> + c2*|b>|a>. The two systems are then said to be entangled. It is a peculiar non classical situation - system 1 is no longer in state |a> or |b> and the same with system 2 - they are entangled with each other. If you observe system 1 and find it in state |a> by the principles of QM the combined system is in state |a>|b> - so system 2 is in state |b> and conversely. Observing one system immediately has told you about another due to entanglement.
This is the weirdness of entanglement - observing one system immediately tells you about the other system and conversely. The difference classically is that the principle of superposition does not hold and you don't have this peculiar relationship involving complex numbers between states. You can in fact have something similar to entanglement classically (by, for example, putting coloured papers in two envelopes - look at one envelope and you know the colour of the other) but its this complex number thing that distinguishes it. The reason you have complex numbers involved, which distinguishes it from classical probability theory, is the requirement for continuity between pure states:
http://www.scottaaronson.com/democritus/lec9.html
This is the background to my statement right at the beginning of this thread that progress has been made in understanding bells inequalities. We understand this essence of QM is the requirement of continuous transformations between pure states and directly leads to entanglement which simply can't be explained classically - in fact it leads to the overthrow of naive reality.
Thanks
Bill
