DevilsAvocado
- 91
Badvok said:Thanks all for your assistance with this but it looks like I'm falling between two stools. On the one hand I see simplified explanations that make assumptions that I can't clearly see the validity of, on the other hand my mathematical ability is not up to the required level to read and fully understand the actual papers. So I have a lot more learning to do before I can get my head around these concepts.
Why do I get the feeling a non-local bullet just penetrated my little green heart...??
Could this be a remedy?
Albert Einstein said:Everything should be made as simple as possible, but not simpler.
If it worked for J.S. Bell, why shouldn’t it work for us? In lectures he used exactly the same example as I gave you:
N(+30°, -30°) ≤ N(+30°, 0°) + N(0°, -30°)
Badvok said:Sorry, I know that, that's not what I meant. I meant that if I choose to measure a particle's position I can do that fairly accurately, I don't limit the position measurement to a yes/no result (is it in one region or another?) And likewise, I can measure momentum fairly accurately without limiting it to a yes/no result. I know I can't measure both on the same particle.
If this is what stopping you from proceeding, I don’t really understand why... on a normal macroscopic scale we can pin down objects to a precise position in continuous space, but can we really do this in the QM world?
Well, from the Stern–Gerlach we know that angular momentum takes only certain quantized values:
https://www.youtube.com/watch?v=rg4Fnag4V-E
Then the question arises - Is space[time] itself quantized?
According to Loop quantum gravity it is, consisting of an extremely fine fabric of finite loops. The size of this structure is the Planck length which is approximately 10−35 meters.
If spacetime is quantized – and you want to measure position – you will get a 'quantized' Yes/No answer...
(Besides, all particles in QM are ‘wobbling around’ due to energy and virtual particles bumping in and out of the QM soup. And if you try to remove the heat/energy by freezing them near absolute zero to a Bose–Einstein condensate and lowest accessible quantum state, they become indistinguishable!)
If it helps, you can think of the entangled photon as having a superposition of all angles between 0-360°, and you can set the polarizer to any degree + arcminute + arcsecond and so on, for any ‘continues resolution’ you want. The answer will however be Yes/No for the measurement...
... I wish I could understand what the problem is ...
