Benzene forms the electron shell configuration of two rings of
In summary, the conversation discusses the possibility of an electron beam causing systematic flow in the ring structure of a benzene molecule. It is suggested that this is a well-known phenomenon called aromatic ring current, and that the reversal of the flow could apply an opposing force to all the electrons. However, it is noted that the figure describing the delocalized orbital may be exaggerated and that the two rings of the orbital should meet at each carbon site.
Diproton
Benzene forms the electron shell configuration of two rings of electrons, parallel to the molecule, shown here http://upload.wikimedia.org/wikiped...e_Orbitals.svg/750px-Benzene_Orbitals.svg.png
so my question is, if an electron beam is run through the center of the benzene, would the resultant magnetic field cause the electrons to flow in a systematic way in the ring?
This actually seems like a viable theory at first, although I am unsure how the electrons would flow stability wise, as the ring structure you mention is not in fact a perfect ring. However you could influence the electron trend.
An interesting question to pose is, if you go the electrons to flow in a specific way, what would happen if the electron beam stopped an a second beam going the opposite way through the benzene molecule started. Theoretically the exact opposite force would be applied to the electrons.
It's not only a viable theory, but a well-known phenomenon called http://en.wikipedia.org/wiki/Aromatic_ring_current" .
Then reversal of the flow could theoretically apply exact opposing force to all of the electrons.
The two rings of a delocalized orbital are not separate entities, just as two lobes of a single p-orbital are not separate. I think the figure describing the delocalized orbital is a little exaggerated. Two rings should meet at each carbon site in the same way as the lobes of their constituent p_z orbitals do.
Related to Benzene forms the electron shell configuration of two rings of
1. What is the electron shell configuration of benzene?
The electron shell configuration of benzene is two rings of six carbon atoms with six hydrogen atoms attached to each carbon atom.
2. How does benzene form this electron shell configuration?
Benzene forms this electron shell configuration through covalent bonding between the carbon atoms. Each carbon atom shares three pairs of electrons with its neighboring carbon atoms, creating a stable ring structure.
3. What makes the electron shell configuration of benzene unique?
The electron shell configuration of benzene is unique because it is highly stable due to the delocalization of electrons throughout the entire molecule. This results in a lower energy state and makes benzene less reactive than other molecules with similar structures.
4. What is the significance of the two rings in the electron shell configuration of benzene?
The two rings in the electron shell configuration of benzene provide additional stability to the molecule. This is because the overlapping of electron clouds in the two rings creates a stronger bond between the carbon atoms, making benzene even less reactive.
5. Are there any practical applications of the electron shell configuration of benzene?
Yes, the electron shell configuration of benzene is the basis for many important industrial chemicals, such as gasoline, plastics, and detergents. It is also a key component in the production of pharmaceuticals and agricultural chemicals.
13K
