Undergrad Bernoulli's equation and the work energy theorem
The discussion revolves around the derivation of Bernoulli's equation, specifically the inclusion of gravitational potential energy alongside kinetic energy in the work-energy relationship. Participants clarify that the work done on the fluid is the sum of contributions from pressure and gravity, emphasizing that pressure work is lateral while gravitational work is vertical. The distinction between net work done on the fluid and work done by pressure is highlighted, with examples illustrating how these concepts apply in different scenarios, such as fluid flow in pipes. The conversation also touches on the role of pumps in doing work on fluids, akin to the heart's function in the circulatory system. Overall, the discussion deepens the understanding of energy transformations in fluid dynamics as described by Bernoulli's principle.
Chenkel
Hello physics researchers, teachers and enthusiasts.
I notice one little thing is confusing me in the derivation of Bernoulli's equation in the article, they write:$$dW = dK + dU$$where dW is the work done to the fluid, dK is the change in kinetic energy of the fluid, and dU is the change in gravitational potential energy of the fluid. But I thought with the work energy theorem, the work done to the fluid is equal to the change in kinetic energy:$$dW = dK$$Why is there an additional term of potential energy in their equation? My apologies if this is a little too simple!
Potential energy is gained or lost if there is a change in height of the fluid as it moves.
Likes Chenkel
I agree with that, but the work done to fluid should equal mgh, so I would expect the work energy equation to be something like $$mgh = dK$$The equation they have is different.
Thank you for the response.
The work energy theorem says ##W_{net}=\Delta K##. The term ##W_{net}## is the sum of two works done on the fluid. One work, ##dm~ g~\Delta h## is done by gravity and the other ##p\Delta V## is done by pressure (see equation 14.8.8).
Likes Chenkel
What happens if the pressure difference is caused by gravity? In that situation would we be summing the work done by gravity twice in a round about way? The mgh term, and the pressure force through a distance term?
Are you asking about the static pressure when the fluid is not moving? Try this at home. Put a straw upright in a glass of water. Plug the top end and lift the straw out of the glass. The water will remain in the straw.
Question 1: What is pressure at the bottom water-air interface? Why?
Now lift your finger that plugs the top end. The water will spill out.
Question 2: As soon as you lift the finger, what is the pressure (a) at the bottom air-water interface and (b) at the top air-water interface? Why?
Likes Chenkel
For question 1: I'm guessing the pressure at the bottom of the straw is 1 atmosphere at sea level, and the pressure at the top of the straw is 1 atmosphere minus ##\rho g h## where h is the height of the straw
For question 2: When you lift your finger I'm guessing the pressure at the bottom is still one atmosphere, and the pressure at the top becomes one atmosphere.
I'm wondering if the pressure in Bernoulli's equation is not pressure from gravity but pressure from some other external force, and I am imagining some moving (non static) liquid. It just doesn't seem to make sense to me to treat the vertical work done by gravity, and the work done by pressure as different work quantities unless the work done by pressure is the result of a non gravitational external force.
##z## for "elevation" in Bernoulli's ( work by gravity per unit mass ). It is a different term than ## \frac{P}{\gamma} ##, they are independent of each other in that derivation. That ##P## is from "something" doing work on the fluid. You are adding the contributions from each together along with a kinetic energy per unit mass ## \frac{v^2}{2g}##to get the total energy per unit mass at some point along a streamline.
Likes Lnewqban and Chenkel
It sounds to me like you are saying the pressure is from something other than gravity in Bernoulli's equation, is it safe to assume in the standard equation that we ignore the effects of gravity on pressure? Also I apologize for being a little new to the terminology, but what is the ##\gamma## in ##\frac {P}{\gamma}## and shouldn't kinetic energy per unit mass be ##\frac {v^2}{2}##?
The pressure from gravity is not ignored, its there. Its just that in the Bernoulli Equation we aren't adding pressures, we are adding energy per unit weight from each contributing source.
Sorry, the terms have dimension energy per unit weight...not mass. My bad.
## \gamma ## is the specific weight of the fluid:
## \gamma = \rho g ##
Where ## \rho ## is the mass density of the fluid
Likes Chenkel
So after looking at the article again I believe I understand it a little better, the work done to the fluid is equal to the sum of the work done in all dimensions (x, y, and z). So this means we need to consider the vertical work done by gravity, and the lateral work done by pressure, we can relate these two quantities with the work energy theorem.
In the derivation of Bernoulli's equation in the article, the work done by pressure is only lateral (not vertical), I'm wondering if the derivation would get a different result if the work the pressure was doing was in the direction of gravity...
Thank you again for the feedback. I believe I understand much more, but I do wonder about the different derivation from vertical or semi-vertical work from pressure.
Likes Lnewqban
The work done by pressure is a path integral. It is the amount of work done on a fluid element as it moves on a path from ##a \to b##. You seem to be concerned about what is happening when the path is going "up"?
Likes Chenkel
I was concerned with what happens in the derivation when the velocity is aiming in a vertical or semi vertical angle (against gravity). I believe angle of the initial and final velocity vectors do not matter now that I've analyzed the problem. The main point I want to make that was initially confusing to me, is that there's a difference between net work done on the liquid, and net work done by pressure. I initially thought I could use the work energy theorem to find the work done by pressure, but the work energy theorem tells us the work done to the fluid, and not the work done by pressure.
To illustrate this point, imagine you have an object and you move it vertically, and it maintains the same velocity at beginning and end, the net work done to the body is 0 even considering gravity (using the energy work theorem), but the net work done by you is mgh (definitely not 0). Now imagine you're the "pressure," and the object you're pushing is the "fluid." You will end up doing mgh joules of work, but the work done to the fluid is still 0.
In summary this explains why ##dW = dK + dU## instead of just ##dW = dK##.
Likes erobz
OK, let me do a series of applications of the Bernoulli equation to find the difference in pressure at two different points of a pipe containing an incompressible fluid. First the continuity equation says that $$Av=\beta=\text{const.}$$where ##\beta## is the volumetric flow, e.g. gallons/minute. I use the continuity equation to eleiminate speed from Bernoulli's equation to get $$p+\frac{1}{2}\rho\left(\frac{\beta}{A}\right)^2+\rho~g~h=\text{const.}$$The pressure difference between two points in the pipe, ##\Delta p=p_2-p_1##, is $$\Delta p=\frac{1}{2}\rho\beta^2\left(\frac{1}{A_2^2}-\frac{1}{A_1^2}\right)+\rho g(h_2-h_1).$$Case I: Horizontal pipe with uniform cross section. WIth ##h_2=h_1## and ##A_2=A_1##,$$\Delta p=0.$$ Case II: Horizontal pipe with change in cross section. WIth ##h_2=h_1##,$$\Delta p=\frac{1}{2}\rho\beta^2\left(\frac{1}{A_2^2}-\frac{1}{A_1^2}\right).$$If ##A_2>A_1##, the pressure drops, else it rises as the fluid flows from 1 to 2.
Case III: Pipe with change in cross section and change in height. $$\Delta p=\frac{1}{2}\rho\beta^2\left(\frac{1}{A_2^2}-\frac{1}{A_1^2}\right)+\rho g(h_2-h_1).$$The change in pressure could be positive, negative or zero depending on the choice of cross-sections and heights.
Case IV: Pipe with change in cross section and change in height but no fluid flow. With ##\beta =0##, $$\Delta p=\rho g(h_2-h_1).$$This is the familiar hydrostatic pressure result. Hydrostatic pressure is built in Bernoulli's equation and does not do additional work when the fluid is moving.
I hope this helps.
  • Love
Likes Chenkel, Delta2 and erobz
I would like to clarify that the principle is based on an isolated system, with neither work or heat coming into it.
The three forms of energy transform into any of the other, according to the flow characteristics, but the amount of internal energy remains the same.
Somehow, it could be compared to the transformation of kinetic and potential energy for a rollercoaster, depending on the cart position.
Please, see:
https://en.m.wikipedia.org/wiki/Bernoulli's_principle
In order to do work on the fluid, a pump is needed, just like the heart does to make blood circulate up and down the body, overcoming the natural resistance from friction and turbulence.
The heart suplies the delta P between its inlet and outlet, but the internal presion in the circulatory system depends on other factors.
Likes Chenkel, erobz and kuruman
Once more it's clear that the confusion comes from the avoidance of math ;-). The equation is derivable from Euler's equation for the perfect fluid
$$\rho [\partial_t \vec{v} + (\vec{v} \cdot \vec{\nabla}) \vec{v}=-\vec{\nabla} P - \vec{\nabla} V,$$
where ##\vec{P}## is the pressure of the fluid and ##V## the potential of the external force density (e.g., $$V=-\rho \vec{g} \cdot \vec{r}$$
for the potential of the gravitational force.
The only trick is to rewrite the "convection term" by calculating the gradient of ##\vec{v}^2##. That's most easily done using the Ricci calculus (for Cartesian components; Einstein summation convention implied),
$$\partial_{j} (v_k v_k)=2 v_k \partial_j v_k = 2 [v_k (\partial_j v_k -\partial_k v_j)+v_k \partial_k v_j] = 2[v_k \epsilon_{jkl}(\vec{\nabla} \times \vec{v})_l +v_k \partial_k v_j] = 2 [\vec{v} \times (\vec{\nabla} \times \vec{v})]_j + 2 (\vec{v} \cdot \vec{\nabla}) v_j,$$
i.e., in vector notation
$$\frac{1}{2} \vec{\nabla} (\vec{v}^2) = \vec{v} \times (\vec{\nabla} \times \vec{v}) +(\vec{v} \cdot \vec{\nabla}) \vec{v}.$$
Plugging this into Euler's equation, you get
$$\rho [\partial_t \vec{v} + \frac{1}{2} \vec{\nabla} (\vec{v}^2) - \vec{v} \times (\vec{\nabla} \times \vec{v})]=-\vec{\nabla}(P+V).$$
Now assuming incompressibility, ##\rho=\text{const}##, ##\vec{\nabla} \times \vec{v}=0##, and ##\partial_t \vec{v}=0## you get
$$\vec{\nabla} \left (\frac{\rho}{2} \vec{v}^2+P+V \right)=0$$
or
$$\frac{\rho}{2} \vec{v}^2 + P + V =\text{const}.$$
That's Bernoulli's theorem with the clearly stated assumptions when it's valid
(a) ideal fluid
(b) incompressibility
(c) stationary flow
(d) irrotational flow
Likes Chenkel, Delta2, erobz and 1 other person
Just as a heads up.
There is a "sticky" situation here. Bernoulli's is derived for inviscid flow. It's just an approximation to real flow over short distances.
The conceptual trouble always comes in when we try to use it to solve for the ## \Delta P ## of straight/uniform horizontal section of pipe. Something that is completely not a problem in real viscous flow suddenly disagrees (dare I say even seems a bit paradoxical) with what we know about flow in pipes. However, it should be expected if we remember the assumptions.
Likes Chenkel, vanhees71 and Lnewqban
or
(a) ideal fluid
(c) stationary flow
Thats notation is a little intimidating though!
Eulers Formula:
$$ -\frac{ \partial }{ \partial l} \left( p + \gamma z \right) = \rho \left( V \frac{ \partial V}{ \partial l} + \frac{\partial V}{ \partial t} \right) $$
(but I even think this is intimidating)
Likes Chenkel
I don't understand your notation. What's ##l##? Also note that the velocity is a vector!
Likes Chenkel
According to the textbook I copied it from ##l## is a pathline in the flow. When they derive Bernoulli’s from it, the assumption is the flow is steady and the “local acceleration” ## \frac{\partial V}{\partial t}= 0##. Then they say that with this assumption the “pathline” becomes a “streamline” ##s## and the derivatives become normal w.r.t. ##s##.
Likes Chenkel and vanhees71
  • · Replies 20 ·
  • · Replies 48 ·
  • · Replies 35 ·
  • · Replies 54 ·
  • · Replies 77 ·
  • · Replies 31 ·
