cianfa72
- 2,817
- 298
To be more precise: in the binary system example above, what is true is that the external work done on the "system" changes the sum of system's potential energy plus the sum of system's components kinetic energies calcuated w.r.t. a given inertial frame. Suppose to pick as inertial frame the frame ##F## where the system's CoM is initially at rest. Upon the external thing interaction with the system (say with B body), the system's CoM will start accelerating w.r.t. ##F##. However the system's total energy change calculated w.r.t. frame ##F## will be exactly equal to the amount of external work done.cianfa72 said:Just to give an example in the realm of Newtonian physics: let's take an isolated binary system made of two bodies A and B rotating around their common Center of Mass (CoM). Now suppose an external thing suddenly interacts with B doing "external" work on the system (where system = binary system). Generally speaking, the system will change both its potential energy and kinetic energy of its components (A and B) w.r.t. their common CoM.
Assuming A much more massive than B, the displacement of A w.r.t. CoM can be neglected, so basically the change in system's kinetic energy is accounted to B kinetic energy (w.r.t. CoM) alone.
Then, assuming body A much more massive than B, one can reasonably neglect the displacement/acceleration of system's CoM, getting back to the result that the system's change in kinetic energy basically goes in the change of B's kinetic energy w.r.t. system's CoM.
