Bessel function Solution to Second order ODE with exponential coefficient
phil ess
Find the general solution to x'' + e^(-2t)x = 0, where '' = d2/dt2
First I did a change of variables: Let u = e^(-t)
Then du/dt = -e^(-t)
dx/dt = dx/du*du/dt = -e^(-t)*dx/du
d2x/dt2 = d/du(dx/dt)du/dt = e^(-2t)*d2x/du2
Subbing into the ODE, I get:
e^(-2t)*d2x/du2 + e^(-2t)x = 0
And I notice that the coefficients are just u^2
(u^2)x'' + (u^2)x = 0
Now at this point I could just cancel out the u^2 and get my sin and cos solutions, but the answer wants Bessel functions, so I use the general solution to ODEs of the form:
x2y'' + x(a+2bxr)y' + [c+dx2s-b(1-a-r)xr+b2x2r]y = 0
with a=0,b=0,c=0,d=1,s=1
The solution is then x(u) = u1/2Zp(u)
With p = 1/2
Or
x(t) = e^(-t/2)[c1*J1/2(e-t+c2*J-1/2(e-t)]
But this isn't the correct answer. There shouldn't be any function of t in front of the bessel functions, and I should be getting Y's and J's of integer order, not just J's of half-integer order.
If anyone has any insights please help!
Thanks
That looks like you're not handling the derivatives and substitutions correctly. I tell you what, suppose I just write it as:
y''+e^{-2x}y=0
just so it's in the form of Wolfram Mathworld syntax for Bessel Differential equation then suppose you make the independent-variable substitution:
x=-\ln(t)
can you now then transform the DE from y as a function of x to a DE in terms of y as a function of t? Once you do that, then compare the resulting DE to the requisite form on the Mathworld site and then back-substitute t=e^{-x}.
I've tried your idea, and it looks like that's pretty much what I've been doing the whole time, so I can't see where I'm going wrong. Here's what I did:
Where am I going wrong? Thanks for the help!
Phil, when you post a real wide picture, it messes up the scrolling of the thread. You wanna' remove that please or post a smaller picture so it doesn't run off the right side of my screen? Look, how about we carefully start from the beginning in nicely-formatted latex. I'll start it for you:
We have:
y''+e^{-2x}y=0
Now let:
x=-ln(t)
then:
\frac{dy}{dt}=\frac{dy}{dx}(-\frac{1}{t})
<br /> \begin{aligned}<br /> \frac{d^2 y}{dt^2}&amp;=\frac{1}{t^2}\frac{dy}{dx}-\frac{1}{t}\frac{d}{dt}\left(\frac{dy}{dx}\right)\\<br /> &amp;=\frac{1}{t^2}\frac{dy}{dx}-\frac{1}{t}\left(\frac{d^2 y}{dx^2}\frac{dx}{dt}\right)<br /> \end{aligned}<br />
Now, can you then follow what I did and then substitute all that into the original equation in x to obtain a DE in t?
Your process makes perfect sense. I've arrived at the desired result! Thanks for clarifying the steps!
