aladinlamp
- 44
- 1
Hi, is Betz law fully applicable for hydro, hydrokinetic submerged turbines, since air is compressible but water is not ?
Betz Law, also known as the Betz Limit, is a fundamental principle in fluid dynamics that states the maximum efficiency of any wind or water turbine is 59.3%. This means that no turbine can convert more than 59.3% of the kinetic energy of the fluid into mechanical energy. This law applies to submerged turbines as they also rely on the conversion of kinetic energy from a fluid (in this case, water) into mechanical energy.
There are no exceptions to Betz Law for submerged turbines. This law is a fundamental principle of fluid dynamics and applies to all types of turbines, including those that are submerged. However, there are other factors that can affect the efficiency of a submerged turbine, such as the design and placement of the turbine in the water.
Yes, Betz Law can be used to predict the maximum efficiency of a submerged turbine. However, as mentioned before, there are other factors that can affect the actual performance of a turbine, so the predicted efficiency may not always be achieved in real-world conditions.
The depth of the water does not affect the application of Betz Law to submerged turbines. This law is based on the principle of conservation of energy and is independent of the depth of the water. However, the depth of the water can affect the performance of a submerged turbine due to changes in water flow and pressure.
Yes, there are other laws and principles that apply to submerged turbines, such as the law of conservation of mass and the law of conservation of momentum. These laws, along with Betz Law, help to explain the behavior and performance of submerged turbines in different water conditions.
