I Bias and dark current from a graph of mean signal vs exposure time
The discussion focuses on determining bias and dark current from a graph of mean signal versus exposure time for dark frames. The average mean signal can provide a rough estimate of bias per pixel, but confusion arises in calculating dark current. If the dark current is low, the mean pixel value closely approximates the bias; however, longer exposures or higher dark currents can lead to significant discrepancies. To accurately find the bias, the slope of the graph should be analyzed, especially if the dark frames have different exposure times, allowing for extrapolation to zero seconds. Understanding these relationships is crucial for accurate measurements in imaging.
beans123
TL;DR Summary
I am attempting to find the bias and dark current from a graph of mean signal (per pixel) vs exposure time (sec) for 8 different dark frames.
I have a graph of mean signal (per pixel) vs exposure time (sec) for 8 different dark frames. I am being asked to find the bias in ADUs/pixel and the dark current in ADUs/sec/pixel and I am very confused on how I could get it. I know that the average of all of the mean signals is a rough guide as to what I should get for the bias per pixel but I'm very confused as to how to find the dark current from the graph.
Astronomy news on Phys.org
Only if the dark current is very low. For example, if the bias is 100 ADU and the dark current is 0.1 ADU/s, and you take an exposure of 10 seconds, the mean pixel value of approximately 101 ADU is very close to the bias. But if the exposures are very long or the dark current is very large then you might wind up with a bias of 100 ADU but a mean pixel value of 150 ADU, in which case you would be off by 50% if you just went with the mean value.
Do these dark frames have the same exposure time, or different? If different, you can find the slope of the graph and extrapolate backwards to zero seconds exposure time to find the bias.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
