Hornbein
- 2,807
The iconic Big Ben clock in London can be seen from any angle in the horizontal plane. It has four faces. How many faces do you need in N dimensions to get that same visibility?
Four!
A clock face can be seen as long as you are not in the same plane as that face, that is, the angle between the observer and the plane is at least 30 degrees. In mundane 3D we have xy and zy faces and an observer's location is [x,y,z]. We assume that vertical y is always more or less zero, as we only care about viewers who on the surface of the Earth. The minimal maximum angle is then when x=z, which means the angle of the observer to both faces is 45 degrees. x<>z increases the maximal angle.
Now we are in N dimensions with N>3. Any component in additional dimensions decreases the dot product, which increases the maximal angle with the clock faces and hence increases visibility. Taking to extremes, if the observer's location is entirely within these new dimensions then the dot product with both face planes xy and zy is zero, the angle between the observer and both clock faces is 90 degrees, and visibility is maximal to two faces.
Note that the clock's numerals and hands are ND or (N-1)D objects. They are arranged in a 2D pattern.
Four!
