Binding Energy in U-235 and daughter atoms
physmurf
I am a little bit confused.
If U235 decays 2 neutrons, and the two daughter atoms posses a larger amount of binding energy per nucleon, then why is there excess energy? Why doesn't this process require the input of additional energy? I know I am missing something fairly simple.
Because binding energy is conted as "negative".
So, wouldn't that imply that this would require energy from the surroundings in order to make the reaction to take place? I know that we can safely assume that the kinetic energy of the incoming neutron to be negligible. So, how can this happen without the addition of external energy?
Well now there is many different ways for the U-235 to decay and being fissioned. Just tell the specific reaction that you have questions about and I will try to explain it.
If the daugher nucleis has greater binding energy per nucleon (i.e. more negative energy), then energy is released (in general, depends on the neutrons also etc but basically this is what happens)
Mother nucleus A' has 20 nucleons, 5MeV / nucleon; total energy: -100MeV
Decays to daughter nuclei B' and C', they have binding energy 6MeV / nucleon; total energy: -120MeV so here you have less energy, so in order to obey energy conservation; 20 MeV is then kinetic energy of daugher nucleis (NB! this is only a crude model for explanation)
Okay, from lecture, the professor uses the following example. U-235 decays to two daughter nuclei X and Y each with A=117 with the release of two free neutrons. He says the change in binding energy = (7.6 Mev * 235 - 8.3 Mev * 234) = (approximately equals) (0.7)(235) = (approximately) 200 MeV.
The above equation will yield a negative energy. Where does the energy come from that allows more overall binding energy between the two daughter nuclei?
Spontaneous fission is that reaction called.
Binding energy is counted as negative, so You have to be aware of this and count backwards.
U-235; 7.6MeV / nucleon
X; Y : 8.3MeV / nucleon respectevly
gives:
235*(-7.6) = -1786MeV initally
2*117*(-8.3) = -1942MeV final
You have more energy in the beginning then in the final state, so you must add energy to obey energy conservation.
So there is relased 256MeV, do the comparison with a hydrogen atom, that is excited and the electron has 1.51eV binding energy; deexcites to ground state that has binding energy 13.6eV; there is realeased 12.89eV as a photon (and recoil energy of atom). So then things is rather clear, cos' binding energy is counted negative, but in nuclear physics, you have to take into account that the initial particle can be divided into two etc, but basically it is the same principle.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
This is still a great mystery, Einstein called it ""spooky action at a distance" But science and mathematics are full of concepts which at first cause great bafflement but in due course are just accepted. In the case of Quantum Mechanics this gave rise to the saying "Shut up and calculate". In other words, don't try to "understand it" just accept that the mathematics works. The square root of minus one is another example - it does not exist and yet electrical engineers use it to do...
