Binomial Distribution for a person walking in straight line
CourtneyS
Can I measure the probability of a person being at a certain end location after n steps using the binomial distribution if,
probability student goes x=x+3 is 0 <= p <0.5 , x=x-1 is 0<= 0.5 p <1.
I know that I can do this for x=x+1 0<=p<0.5 and x=x-1 0.5<=p<1
And I know it doesn't work if it's position based, so for example at x=10, the probabilities changed.
But, can I do it if they move a larger distance in one direction than the other such as the example I have posted?
Thanks
Thanks
I think you meant to say that the moves are ##x \to x+3## w.p. ##p## and ##x \to x-1## w.p. ##q = 1-p##; here ##0 < p < 1/2##. (The case ##p=0## should be excluded, because it is trivial---there is no randomness at all.)
After ##n## steps, if the student takes ##k## steps to the right and ##(n-k)## steps to the left, how far to the right has he/she moved? (Of course, a negative distance to the right is a positive distance to the left.)
I did not understand at all the rest of your post, where you talk about x = 10 and larger distances, etc.
Can I say that probability for any given end point x, the probability of ending up there is :
probability = {factorial(n)/(factorial((n+(x+3))/2)*factorial((n-(x-1))/2))}*{p^(1/2(n+(x+3)) * q^(1/2(n+(x-1)))}
Where p = probability of moving x+3 and q = 1-p
That is not what I get. Just solve for ##k## in terms of ##x## and substitute that into the binomial expression, but do it carefully. (Of course, I assume the starting point is ##x = 0##).
BTW: it is normal in probability to use shorthand notation for binomial coefficients: instead of
\frac{a!}{b! (a-b)!}
we usually write
\binom{a}{b} \;\;\rm{or} \;\; C(a,b) \;\; \rm{or} \;\; {}_aC_b
Of course, when we actually want to compute the binomial coefficient, we fall back on the original formula in terms of factorials. However, do what makes you most comfortable; I am just offering advice that you can take or leave.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
