Black-body radiation of a parabolic mirror in a vacuum violates thermodynamics?
In summary: I'm not sure which one applies here.In summary, the conversation discusses a scenario where a parabola with a mirrored surface and a blackened exterior is placed in a vacuum chamber, creating a potential violation of the second law of thermodynamics. The discussion focuses on the directionality of the black-body radiation emitted from the inside of the parabola and how it contributes to the heating of one side of the chamber. The key mistake is that the mirror is not a black body and therefore does not emit black-body radiation. The conversation also touches on concepts such as reflection, absorption, and the Stefan-Boltzmann law.
Norseman
24
Preface:
I understand that regardless of any further details, the correct answer is "No, it does not, because..." I'm looking for an answer because clearly I don't understand something about either thermodynamics, mirrors, or black body radiation. In my mind, the scenario I describe follows the rules of black body radiation and mirrors to violate the second law of thermodynamics. This is almost certainly incorrect, so I need someone to tell me what I'm getting wrong.
Scenario:
Imagine you have a 1 meter long and 200 cm wide aluminum parabola with a 99% reflective mirrored surface on the inside. Suppose the outside of the parabola has been blackened by a laser. To keep this mentally simple, let's get rid of convection by placing this mirror in a chamber with a near-perfect vacuum, and let's get rid of conduction by placing the chamber and mirror on the international space station so that the mirror can stay in the middle of the chamber without touching anything. Assuming you don't change the temperature of the chamber, the mirror and chamber should (presumably) reach an equilibrium at room temperature.
Problem:
The mirror will produce black-body radiation. However, most of the black-body radiation emitted from the inside of the parabola will be reflected in a single direction, towards the chamber. This means that the parabola will be emitting directed energy which heats up one side of the chamber. We should be at thermodynamic equilibrium, but we're not. What's going on here?
Science news on Phys.org
How do you know this? By "single direction" you mean a parallel beam?
And why do you think that the back of the mirror does not emit?
A parabola can reflect everything coming from one specific direction to a specific point. Everything else will have a focus elsewhere.
If the inside is reflecting in the infrared, it will not emit much radiation (it is "white"). Photons from the chamber walls just hit the chamber walls again, some photons stay at the parabola, some photons are emitted by the parabola. There is nothing special about the shape here.
No, but a somewhat focused beam. If you imagine a line going from the center of the parabola and extending outward, I think most of the energy would be focused to within 60 degrees of that line.
Parabolas tend to reflect light away from themselves in mostly the same direction, right?
I think it would emit at least as much as the mirror. The Stefan-Boltzmann law suggests that temperature and surface area are the only variables which determine the energy released by black-body radiation. It might be the case that the blackened exterior is hotter than the reflective interior, but I think that would mean that the system is not in thermodynamic equilibrium.
The problem is that the mirrored surface is reflective, while the exterior is not. The exterior would be very good at absorbing heat, the interior would be very good at reflecting it. This might create a cycle where heat is absorbed by the exterior of the parabola, then emitted by both the exterior and interior, but focused in a certain direction when it's emitted by the interior.
Right, it wouldn't be precisely focused. But it would be more focused than ordinary.
If I understand you correctly, this might be the explanation. Are you saying that reflective surfaces tend to emit less radiation, or tend to emit a different spectrum of radiation?
If it helps, let's try something that just seems wrong: a perpetual motion device. Imagine you place a blackened cap on the end of the parabola to absorb the heat, and you thoroughly insulate the cap so that it can get quite hot. Then, you use the hot cap to run a heat engine at room temperature without any input of energy. Where would this device fail?
Edit: Intuitively, I'd say that the cap would not get hot at all, but I can't explain why. The mirror would radiate heat and most of it would be reflected to the cap. Most of the heat radiated from the cap to the mirrors would also be reflected back to the cap. How is it possible that the cap would stay cool, or would the device actually heat it up but fail at some other point?
Here is the key mistake. The mirror is (by definition) not a black body and will not produce black-body radiation. In this case, the mirror is 99% reflective, which means that it absorbs only 1% of the energy of a black body at the same temperature and also it emits only 1% of the energy of a black body at the same temperature.
True, but the back of the mirror is a black body. Heat would be conducted from the blackened exterior to the reflective interior, right?
Or does the mirror actually emit less energy even if it's at the same temperature?
Yes.
Very cool. While I was waiting for a reply I checked some Wikipedia articles regarding non-black body radiation (it didn't even occur to me to check for that!) and found Kirchhoff's law of thermal radiation, Low emissivity, and Thermal radiation which indicate that for any material, the coefficients of emissivity and reflectivity should add together to equal 1.
Thanks for helping me everyone. :)
FAQ: Black-body radiation of a parabolic mirror in a vacuum violates thermodynamics?
1. What is black-body radiation?
Black-body radiation refers to the electromagnetic radiation emitted by an object that absorbs all incident radiation and reflects none. It is considered a perfect radiator and follows a specific distribution curve based on its temperature, known as the Planck's law.
2. How does a parabolic mirror emit black-body radiation?
A parabolic mirror is designed to reflect and concentrate electromagnetic radiation, including black-body radiation. The shape of the mirror allows for the radiation to be focused onto a specific point, increasing its intensity.
3. How does black-body radiation of a parabolic mirror in a vacuum violate thermodynamics?
According to the Second Law of Thermodynamics, heat always flows from a hotter object to a cooler object, and the total entropy of a closed system cannot decrease. However, in the case of a parabolic mirror emitting black-body radiation in a vacuum, the radiation is being focused onto a single point, resulting in a higher temperature at that point. This violates the Second Law of Thermodynamics as the heat is not flowing from a hotter object to a cooler object.
4. Why is violating thermodynamics a concern for black-body radiation of a parabolic mirror in a vacuum?
Thermodynamics is a fundamental principle in physics that governs the behavior of energy in a system. Any violation of this law would challenge our understanding of how the universe works and could potentially lead to major revisions in our current theories.
5. Is there any explanation for the apparent violation of thermodynamics in this scenario?
Yes, there are various theories and explanations that attempt to reconcile the violation of thermodynamics in this scenario. Some suggest that the apparent violation is due to the limitations of our current understanding and that further research and advancements in technology could provide a better explanation. Others propose alternative theories, such as the concept of negative temperature, to explain the phenomenon.
