Black holes and the first law of thermodynamics
In summary: While this thread is marked basic, you still might find this old library entry regarding black hole thermodynamics...In summary, the first law of thermodynamics states that matter cannot be destroyed, only transferred from one state to another. When matter is consumed by a black hole, it stays within the black hole and is considered to be destroyed. This is because the matter is not accessible from outside the event horizon. However, over extremely long time scales, the black hole may radiate some energy, but the matter inside will remain. This still holds true to the first law of thermodynamics as energy is not destroyed, but rather converted into different forms. Additionally, physicists do not define matter as a "thing", but rather talk about its properties, which
ElliotSmith
168
104
TL;DR Summary
Is matter consumed by a black hole truly destroyed, or?...
The first law of thermodynamics states that matter can only be transferred from one state to another, and cannot be truly destroyed.
What happens to matter consumed by a black hole? What happens to it and where does it go? Does the first law still hold true?
Astronomy news on Phys.org
It does not state this. It relates internal energy of an isolated system to work done and heat.
Likes Vanadium 50
yes
Matter and energy are interchangeable. What goes into a black hole stays in a black hole. It is still spinning and has charge. You can take angular momentum from a black hole. Some Hawking radiation may come out. But things that went in are gone. We will never get information from them.
It goes into the black hole. It stays right there. That is the end destination.
Over obscene time scales the black hole may radiate enough energy to be equal to the mass that fell in. On Earth we use a platinum bar located in a vault in France to measure a kilogram. This platinum will quantum decay much faster then any stellar mass black holes. The black hole is going no where on the timescale of our finest instruments. It is the ultimate ground state. You cannot go any lower.
No we do not. Not since the SI units were redefined two weeks ago.
It depends on how you define matter, but still it is very misleading. The way people usually define matter makes it a "thing", and energy is a property of that thing. Things and their properites are not interchangable.
Likes davenn and Orodruin
The important bit in this is "...define matter...". Physicists don't usually define "matter", they talk about the properties of matter, which include mass and energy, (and spin... charge...). You can make a good argument that the only things that actually exist are the properties. At a particle level these are quantum numbers. When we are talking about mass and black holes the only way that counts (I nearly wrote 'matters') is the definition in General Relativity with mass and energy interchangeable. Everything else , including "The way people usually define ...", is only an approximation/guesswork.
In the case of a black hole, the sets of numbers which are particles end up on the other side of the event horizon from whence we can never recover them.
  • Skeptical
Likes davenn
Well I think what he meant to say is that mass and energy are interchangeable when anything can move at a speed which can be compared to the speed of light.
ElliotSmith said:
Summary: Is matter consumed by a black hole truly destroyed, or?...
Well everything that goes into the black hole stays in the black hole. the black hole starts gaining mass and some Hawking radiation may be released in these cases. and yeah the matter that goes into the black hole is destroyed to its atom and then the atoms start moving in the black hole creating more mass as stated above.
Somethings I said may be wrong so sorry for that and tell me where I am wrong. Thanks
  • Skeptical
Likes davenn
This is wrong and you simply cannot state this. If you are not reasonably certain of your statements then you should not be making them. It will just confuse and mislead others.
Likes davenn
@ElliotSmith, it is a few years old, but Brian Koberlein gives a good treatment of black hole thermodynamics at https://phys.org/news/2014-09-black-hole-thermodynamics.html, with some follow-on articles that delve into specific aspects such as 'hair', in-falling matter, and light orbiting a BH. He does not go into math, so it may not be as detailed as you are seeking, but it seems to address your question at a conversational level.
But still they think about it as a 'thing', and energy is a property of that thing, so you can't say that matter and energy are interchangable just like 'strawberry' and 'red' are not interchangable.
And properties of matter are not the same as matter. I know it's semantics, but I think that these semantics are very important. Especially when there are so many misconceptions about mass and energy in relativity. For example this:
as is stated is not true (unless you use an outdated concept of relativistic mass). Mass (meaning invariant mass) of a system depends on it's energy, of course, but that does not mean that mass and energy are interchangable. Proper relation between mass and energy of a particle looks like this (setting ##c=1##) : ##E^2=p^2+m^2##. It contains momentum!
Likes davenn
While this thread is marked basic, you still might find this old library entry regarding black hole thermodynamics useful-
https://www.physicsforums.com/threads/black-hole-thermodynamics.762982/
Related to Black holes and the first law of thermodynamics
1. What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. It is formed when a massive star collapses under its own weight.
2. How does the first law of thermodynamics apply to black holes?
The first law of thermodynamics states that energy cannot be created or destroyed, only transferred or converted. In the case of black holes, it applies to the energy of matter and radiation that falls into the black hole, as well as the energy of the black hole itself.
3. Can black holes violate the first law of thermodynamics?
No, black holes do not violate the first law of thermodynamics. The energy of matter and radiation that falls into a black hole is not destroyed, but rather converted into the energy of the black hole itself.
4. How does Hawking radiation relate to the first law of thermodynamics and black holes?
Hawking radiation is a type of radiation that is predicted to be emitted by black holes. It is theorized that this radiation is a result of the first law of thermodynamics, as it allows black holes to gradually lose mass and energy over time.
5. Are there any exceptions to the first law of thermodynamics when it comes to black holes?
No, the first law of thermodynamics applies universally to all physical systems, including black holes. However, the extreme conditions of a black hole may lead to unique effects, such as Hawking radiation, that may seem to contradict the law at first glance.
  • Astronomy and Astrophysics
