Block and acceleration of wedge
In summary, the minimum acceleration from the block to remain on the wedge without sliding is when the static friction force is at a maximum.
Mr Davis 97
1,462
44
A block rests on a wedge inclined at angle ##\theta##. The coefficient of friction between the block and plane is ##\mu##. The wedge is given a horizontal acceleration ##a##. Assuming that ##\tan \theta > \mu##, find the minimum acceleration from the block to remain on the wedge without sliding
Newton's second law
Law of static friction
So essentially, I feel as though I have the correct solution, but I am not sure why it is the solution, physically.
So we have three forces acting on the block. the normal force, friction, and gravity.
If we define our coordinate system so that the y-direction is up and the x-direction is down, then we have the following equations:
y-direction: ##N \sin \theta + f \sin \theta - mg = 0##
x-direction: ##N \sin \theta - f \cos \theta = ma##
then
##N \cos \theta + f \sin \theta = mg##
Since ##\tan \theta > \mu##
we know that ##f = \mu N##
Then
##N (\cos \theta + \mu \sin \theta) = mg##
##N (\sin \theta - \mu \cos \theta) = ma##
##\displaystyle a = \frac{g(\sin \theta - \mu \cos \theta)}{\cos \theta + \mu \sin \theta}##
I think that this is the expression for the minimum, but I am not sure why this is the minimum. What is the condition that makes this expression the minimum, rather than just some acceleration?
In what direction is the acceleration? Horizontal could be to the left or to the right. This will affect whether the friction is up the incline or down the incline. However, there are two coefficients of friction, static and kinetic. Which one is equal to tanθ and which one should appear in the answer? How did you choose your coordinate axes? I cannot tell from the equations you show.
The friction in this case would be static. Also, acceleration is to the right, so right is positive and up is positive. The friction will be towards the top of the inclined plane.
Which way is downhill for the incline? To the right or to the left?
To the right
Mr Davis 97 said:
Assuming that ##\tan \theta = \mu##, find the minimum acceleration from the block to remain on the wedge without sliding
Did you mean to type "Assuming that ##\tan \theta > \mu## ...?
Oops, yes.
It's not surprising, your working does not seem to involve anything physical. The maths needs to be motivated from your understanding of the physics... this also helps you check your answer.
You should make a statement at the start about the physical conditions needed for the block to not slide down the wedge (hint: talk in terms of the sum of forces).
If I define x to be horizontal, and y upwards, and do my working in the lab frame, then to stop the block falling I need to provide an upwards force equal and opposite gravity. That way, provided there was no initial vertical component, the only non-zero acceleration will be horizontal. I can do this by directly pushing upwards on the block, with force mg, and so have no net acceleration at all ... but that option is not available ... instead I am forced to push on the block at an angle... that help?
This is the same sort of physics as a sailboat tacking at an angle to the wind.
I assume that when the problem says "the weight is given a horizontal acceleration a" this means that a horizontal force F is acting on the block. This force is necessary since the block is initially at rest. You need to include that force in your equations because ma is not a force. Also, since the block is moving, which of the two coefficients of friction do you think should appear in the equations? That's why I asked which one is given. Finally, you need to consider that the acceleration has both an x and a y component in the horizontal-vertical coordinate system.
To understand why your answer gives you the minimum acceleration, you need to understand why you wrote ##f = \mu N## for the friction force. Under what condition does this formula give the static friction force?
##f = \mu N## when the static friction force is at a maximum, and relative motion ensues, right?
Yes
Relative motion need not happen, but ##f = \mu N## does indicate that the object is "on the verge of slipping".
Related to Block and acceleration of wedge
1. What is the block and acceleration of wedge?
The block and acceleration of wedge is a physical concept that describes the motion of a block that is placed on a wedge-shaped surface. The wedge is typically a triangular-shaped object, and the block is a rectangular object with a flat bottom that rests on the wedge's surface.
2. How is the block and acceleration of wedge calculated?
The block and acceleration of wedge can be calculated using the formula a = g * sin(theta), where a is the acceleration of the block, g is the acceleration due to gravity (9.8 m/s^2), and theta is the angle of incline of the wedge.
3. What factors affect the block and acceleration of wedge?
The block and acceleration of wedge can be affected by several factors, including the mass of the block, the angle of incline of the wedge, and the coefficient of friction between the block and the wedge's surface.
4. Can the block and acceleration of wedge be negative?
Yes, the block and acceleration of wedge can be negative if the wedge is facing downwards and the block is moving in the opposite direction. This can happen if there is an external force acting on the block that overcomes the force of gravity pulling it down the incline.
5. How does the block and acceleration of wedge relate to real-world applications?
The concept of block and acceleration of wedge can be applied to various real-world scenarios, such as ramps, slides, and even roller coasters. It helps us understand the motion of objects on inclined surfaces and can be used to design structures that require objects to move at a certain speed or direction.
