Block attached to spring on slope
The discussion focuses on a block attached to a spring on a sloped surface, analyzing its equilibrium and motion. At equilibrium, the spring's extension is determined by balancing the spring force with the gravitational component acting along the slope, resulting in x = -Mgsin(θ)/k. The block's motion up and down the slope is shown to be simple harmonic motion, with the angular frequency ω = √(k/M), independent of the angle θ. The participants clarify that the x in the motion equation represents the displacement from equilibrium, not just the equilibrium extension. The conversation emphasizes the importance of correctly identifying forces and deriving acceleration to validate the motion's characteristics.
ethan123
A block of mass M can slide freely (without friction) on a flat surface held at an angle \theta to the horizontal. The block is attached to a spring of natural length l and spring constant k. The other end of the spring is fixed to a nail driven into the sloping surface.
i) At equilibrium, by how much is the spring extended?
ii) The block is set in motion directly up and down the slope (i.e. not across the slope). Show that the result is simple harmonic motion with an angular frequency which does not depend on \theta.
F=-kx
i) To be in equilibrium the net force on the block must be zero. So using vector diagram, I got:
F_{spring}=Mgsin(\theta)
and
F_{normal}=Mgcos(\theta)
Then,
F_{spring}=Mgsin(\theta) =-kx
x=\frac{-Mgsin(\theta)}{k}ii)
I know to show simple harmonic motion need to show that:
a=-\omega^2x
I was thinking taking the second derivative of the x found in the above part to find a, but isn't that x the distance the spring is extended when at equilibrium, not a formula for the x position?
...You mean you don't know what the "x" in the formula you have to demonstrate means?
You should ask then.
But does it matter?
Your process is the same: derive the formula for acceleration as a function of x and see if it matches. If you like you can keep track of both the overall extension and the extension at equilibrium and see which one matches the formula you have to show.
Thanks for the reply
So letting x_0 be the distance from equilibrium.
F=kx
ma=kx
a=\frac{k}{m}x
And since \omega =\sqrt{\frac{k}{m}}
a=\omega^2x
And the x found in part i) would be the distance from the natural length of the spring to equilibrium.
Does this make sense?
No - if you just let the box rest at equilibrium, what is it's acceleration?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
