Block Slides on Rough Horiz Surface with Pic
  • Thread starter Thread starter hodgepodge
    Block Surface
hodgepodge
A block slides on a rough horizontal surface from point A to point B with a force of magnitude 2 Newtons acts on the block between points A and B. Points A and B are 1.5m apart. If the KE of the block at A is 5 joules, and KE at B is 4J, how much work is done on the block by the force of friction as the block moves from A to B
my crude rendering of said block:
http://img69.imageshack.us/img69/2411/30326150.th.png
change in E mechanical=Work done by other forces - Force of friction * distance
change in KE = Force * distance + Work done by friction
-1 = 2 cos 40 * 1.5 + Work done by friction
-1 = 2.29813 + Work done by friction
-3.298J = Work done by friction
is this correct?
i got -3.298J
This equation is incorrect. The correct equation (Work-Energy Theorem) says
Change in KE = Sum of the work done by all the forces.
How many forces are doing work and what is the work done by each force? Call the unknown work done by friction Wf, write the Work-Energy Theorem correctly and solve for the unknown Wf.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
