- #71
- 3,449
- 1,239
rcgldr said:A wing does not act like half a venturi. Instead if the wing is not stalled, then the air flow tends to follow a convex surface. The curved path of the air is associated with centripetal acceleration and a pressure gradient perpendicular to the streamline, with the lower pressure on the inside of the curve. The pressure gradient perpendicular to the flow also affects acceleration of air in the direction of flow, but to apply Bernoulli to the inside flow versus outside flow requires separating the flow into multiple streamlines.
It's certainly true (and important) to note that a wing is not like half of a Venturi, as has been discussed at great length on this site before. However, your statements about streamline curvature and the resulting conclusions are not accurate. It is certainly true that curved streamlines, as with any other curved path, require a centripetal force and that force is provided by a pressure gradient. The pressure therefore decreases in the direction of the center of curvatures. However, this pressure gradient points exactly normal to the flow direction and the only role it plays in accelerating the flow is that of the centripetal acceleration, i.e. it changes the velocity of the flow since it "causes" curvature, but it doesn't change the magnitude of the velocity. If there is any tangential acceleration to the flow, it is not related to the streamline curvature through the centripetal acceleration.
Additionally, in situations such as an airfoil where the typical frame of reference is a uniform free stream moving over an airfoil, then every streamline starts with the same total pressure and Bernoulli's equation applies everywhere, not just along a single streamline and regardless of your so-called streamline curvature effect. The exception is when a streamline enters the boundary layer region, at which point viscosity is non-negligible and Bernoulli's equation no longer applies.
Capn'Tim said:You are referring to laminar flow. Laminar flow is important mainly to prevent airflow separation from the wing upper surface which creates turbulence, decreases velocity and results in loss of pressure differential, i.e, lift (wing stall).
Quite the opposite, actually. laminar flow is exceptionally susceptible to boundary-layer separation/stall, which turbulent flow is much more resistant to separation. In situations where high angle of attack maneuvers are common (e.g. fighter jets) there are often elements of the design intended to ensure turbulent flow over the wings so that separation does not occur.
Capn'Tim said:There are indeed multiple streamlines if measuring pressure gradient and velocity across the wing surface and the free air stream. At the wing surface the velocity is lower due to parasitic drag and higher at some point just above the surface- a gradient.
For air blowing over a stationary airfoil, the flow velocity at the surfaces isn't just lower. It's zero. This is not due to "parasitic drag", but due to viscosity, which leads to one component of total drag: skin friction drag. If you instead imagine stationary air with a wing moving through it, this is the equivalent of the wing dragging some of the air along with it since the flow velocity relative to the surface must be zero at the surface.
For now it is easier to work in the frame of reference of a stationary wing with air moving over it. The two frames are equivalent anyway. So, at the surface the velocity is zero, and a short distance away, the velocity is the same as that predicted by inviscid theory, often called the edge velocity. The relatively thin region near a surface that features the smooth change from zero to the edge velocity is called the boundary layer. As luck would have it, nature loves us and the pressure gradient in the wall-normal direction through the boundary layer is very nearly zero, so when we do simple inviscid simulations to come up with the edge velocity, we can treat that corresponding pressure as if it was touching the surface anyway.
Capn'Tim said:Because of the above it is important keep the wing surface very clean in order to support the laminar flow efficiency.
Keeping the boundary layer laminar over the wings of a transport/cargo plane (i.e. one that doesn't do a lot of high angle maneuvering) would be very nice in terms of efficiency. In fact, it's estimated that laminarizing the boundary layers on the wings of a Boeing 737 would result in a 15% fuel savings. However, this process is extraordinarily more complicated than just keeping the wing surface clean. Even if it was that simple, that would be nigh on impossible in any real-world situation.
Capn'Tim said:To be more complete though, one has to factor in equal and opposite action. deflection of airflow beneath the wing creates an equal and opposite force contributing to lift. This however is more prominent during low speed high angle of attack (angle of airfoil to airflow).
This is literally always the case, not just during high angle of attack situations. The momentum change of of the air due to the deflection caused by the wing is exactly equal to the forces on the wing, both lift and drag. This is always true. The Bernoulli explanation and the flow deflection explanation are not two different mechanisms contributing to lift. They are, in fact, two sides of the same coin, and each individually can account for 100% of the lift.
Capn'Tim said:The primary lifting moment comes from entrainment of the air just behind the highest area of effective camber creating low pressure.
Given that a symmetric airfoil (with zero camber) can generate lift, that should tell you that camber is not required for lift, and therefore cannot be somehow fundamental to lift.
