Blue or green solar thermal collector?
  • Thread starter Thread starter Chiel555
The discussion centers on the efficiency of solar thermal collectors with black adsorbers compared to potential blue or green alternatives. Black adsorbers are effective because they absorb a wide range of the electromagnetic spectrum, including infrared radiation, which is crucial for heat transfer. While colored adsorbers might reflect visible light, they could potentially absorb non-visible wavelengths better, but overall efficiency is likely to be lower than that of black adsorbers. The conversation also highlights the importance of using the correct terminology, emphasizing "absorption" over "adsorption" in the context of heat transfer. Ultimately, the key factor in solar collector performance is not just absorption rates, but also how well they manage low-temperature radiation.
Chiel555
Hello, i have a question;
The most solar thermal collectors i have seen have a black adsorber; this adsorbs the visible part of the electromagnetic spectrum; that's why they are black right?
is het possible to have an adsorber painted green or blue which still adsorbs a reasonable amount of the electromagnetic spectrum ( i mean the full electromagnetic spectrum: visible and non visible )? ;
it will reflect the green or blue light( because that's the reason it looks green or blue) so it will adsorb less of the visible part electromagnetic spectrum than a black adsorber;
but maybe it will adsorb some lightwaves from the non visible part of the electromagnetic spectrum better than a black adsorber; so that in total it might adsorb more or less the same light energy as a black adsorber
Is there a reason you want this solar collector to be blue or green versus black? Almost certainly it will not be as efficient.
Also, are you using the term "adsorption" on purpose? It seems like you should be using "absorption" for the heat transfer: https://chembam.com/definitions/adsorption-vs-absorption/
Nobody said that it'll absorb only the visible spectrum.
Actually, usually it's absorbing quite an amount of IR (thermal) radiation too.
(And UV too, but that's not much - not much coming through the atmosphere anyway.)
Google up 'selective solar coating'.
Ps.: the key point is actually not the absorption - it's usually above 90%. It's the low temperature radiation, what makes the difference for these solar paints...
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
