Boat's conservation of momentum
The discussion revolves around the conservation of momentum in a system of three boats, each with mass P, where two identical loads of mass P1 are thrown from the middle boat to the front and rear boats. The initial speeds of the boats are the same at v, and the loads are thrown with speed u relative to the middle boat. The momentum equations are set up for the system, leading to the conclusion that the final speeds of the boats, v1 and v3, should incorporate the variable u. However, there is confusion regarding how to express these speeds in terms of u, as attempts to simplify the momentum equations seem to eliminate u. The discussion suggests starting with the momentum of the first boat after the load is dropped to derive v1.
quark001
Three boats with the same mass P travel in line ahead (one after the other) with the same speed v. Two identical loads of mass P1 each are thrown simultaneously from the middle boat to the front and rear boats with the same speed u relative to the boat. What are the speeds of the boats (v1, v2, and v3) after the loads have been thrown across?
My attempts:
The speed of the masses relative to the ground will be v+u and v-u. Considering only the second boat and applying conservation of momentum, you get: Pv = (P - 2P1)(v2) + P1(v + u) + P1(v - u), and v2 = v. That part is fine.
Now considering all the boats in the initial, final, and intermediate stage: 3Pv = (P+P1)v1 + (P+P1)v3 + (P-2P1)v = 2Pv + (P-2P1)(v) + P(v+u) + P1(v-u). Now the expressions for v1 and v3 as given in the solutions section should not contain v1 or v3, and they must contain u. I don't understand how that's possible since if you simplify the rightmost side of the equation, u is eliminated.
I don't quite understand your reasoning. Why not just find the speeds v1 and v3 just like you found the speed v2? You'll get your answers in terms of v and u.
If you simplify 2Pv + (P-2P1)(v) + P(v+u) + P1(v-u), you get 2Pv + (P-2P1)(v) + 2Pv = 5Pv - 2P1v. I could solve for v1, but my answer was independent of u.
Sorry, but I don't understand what you're doing.
Try this. Start with boat 1. What is its total momentum after the load is dropped into it? Use that to solve for v1.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
