Bohmian Mechanics and The Quantum Sweeper Effect
In summary: The Bohmian approach to QM is more compatible with the nonlinearities of the sweeper effect because it can account for them explicitly. The Standard view is still compatible with those effects, but it does not take into account the quantum potential.
bohm2
828
55
In his criticism of David Bohm’s causal interpretation of the quantum mechanical formalism, Isidor Rabi made the following statement in the 1950ies which is still shared by quite some researchers today:
"I do not see how the causal interpretation gives us any line to work on other than the use of the concepts of quantum theory. Every time a concept of quantum theory comes along, you can say yes, it would do the same thing as this in the causal interpretation. But I would like to see a situation where the thing turns around, when you predict something and we say, yes, the quantum theory can do it too. Although doubtlessly the project of a causal interpretation á la de Broglie–Bohm has gained momentum in recent years, with many of its results exhibiting more detailed illustrationsvia particle trajectories, in fact no experimental prediction unknown to orthodox quantum theory has yet arisen from this approach."​
In the present paper we discuss a finding based on a causal view of quantum mechanics that amounts to a new effect which has so far eluded orthodox quantum mechanics...
We have described the phenomenology of these quantum sweeper effects, including the bunching together of low counting rate particles within a very narrow spatial domain, or channel, respectively. However, we also stress that these results are in accordance with standard quantum mechanics, since we just used a re-labeling and re-drawing of the constituent parts of the usual quantum mechanical probability density currents. However, concerning the explicit phenomenological appearances due to the nonlinear structure of the probability density current in the respective domains for very low values of a, our subquantum model is better equipped to deal with these appearances explicitly.
http://arxiv.org/pdf/1502.04034.pdf
Extreme beam attenuation in double-slit experiments: Quantum and subquantum scenarios
http://arxiv.org/pdf/1406.1346v1.pdf
Even though the two formulations of quantum mechanics (standard and Bohmian) have identical measurable predictions, this paper demonstrates that in some cases the Bohmian approach is more illuminating.
Those interested to learn more about such cases can see the book:
https://www.amazon.com/dp/9814316393/?tag=pfamazon01-20
It's very interesting to see how the different models/interpretations of QM lead to different insights. If people had kept thinking of QM in the orthodox manner, I don't think a lot of these discoveries would be made.
Likes Demystifier
Could you perhaps summarize in a few sentences how the Bohmian approach with its quantum potential explains better the nonlinearities of the sweeper effect? And how is the Standard view compatible with those effects too?
Related to Bohmian Mechanics and The Quantum Sweeper Effect
1. What is Bohmian Mechanics?
Bohmian Mechanics, also known as the de Broglie-Bohm theory, is a quantum theory that proposes a deterministic and non-local interpretation of quantum mechanics. It was developed by physicist David Bohm in the 1950s as an alternative to the Copenhagen interpretation of quantum mechanics.
2. How does Bohmian Mechanics differ from other interpretations of quantum mechanics?
Unlike the Copenhagen interpretation, which states that particles do not have definite properties until they are observed, Bohmian Mechanics posits that particles have well-defined positions and trajectories even when they are not being observed. It also incorporates the concept of non-locality, meaning that particles can instantaneously affect each other's behavior regardless of distance.
3. What is the Quantum Sweeper Effect?
The Quantum Sweeper Effect is a phenomenon that can occur in Bohmian Mechanics when there is a high degree of entanglement between particles. It occurs when one particle's trajectory is affected by the presence of another particle, even if the two particles are not directly interacting with each other. This effect is a result of the non-locality inherent in Bohmian Mechanics.
4. How does Bohmian Mechanics explain the wave-like behavior of particles?
In Bohmian Mechanics, particles have a definite position and trajectory, but they are also guided by a quantum potential that is determined by the wave function. This potential influences the particles' trajectories and can account for the wave-like behavior observed in quantum systems. This theory also explains the phenomenon of wave-particle duality, where particles can exhibit both particle-like and wave-like behavior.
5. Are there any experimental tests that support Bohmian Mechanics?
There have been several experiments conducted that show results consistent with the predictions of Bohmian Mechanics. One notable example is the delayed-choice quantum eraser experiment, which demonstrated the non-local effects predicted by this theory. However, there are still ongoing debates and discussions among physicists about the validity and applicability of Bohmian Mechanics.
  • Quantum Interpretations and Foundations
12K
9K
28K
