- #141
- 13,361
- 3,477
So J is unbounded because of L, irrespective of spin.
Fredrik said:Your [itex]J^2[/itex] is the total (squared) angular momentum operator. I agree that it's unbounded, because [itex]\vec L=\vec x\times \vec p[/itex], and both x and p are unbounded.
A. Neumaier said:He defines the spectrum, I defined the norm.strangerep said:But is your definition above equivalent to Hurkyl's?
Hurkyl said:A complex number x is in the spectrum of T if and only if (T-x) is not
invertible. The norm is the supremum of the absolute values of the
numbers in the spectrum.
A. Neumaier said:In C^*-algebras, both statements are theorems.
strangerep said:Actually, Hurkyl defined a norm as well:
I was really just checking whether both his and your definitions
of norms are essentially the same norm, i.e., just different ways
of defining the same norm (meaning that both norms always give the
same result when applied to any arbitrary element of the algebra).
A. Neumaier said:strangerep said:But the spectrum of [tex]J^2[/tex] is unbounded, [...]
I.e., 0, 1/2, 1, 3/2, 2, ...
Does this mean that even this elementary case can't be handled
in the context of C* algebras?
One handles unbounded self-adjoint operators A by considering instead
the bounded family of operators exp(isA), s real. [...]
strangerep said:Thinking more about (un)boundedness of observables in a strictly
algebraic context (i.e., without Hilbert space), I'm wondering
how one would derive the usual angular momentum spectrum
in this context (if we didn't already know it).
In standard QM with Hilbert space, etc, one takes the usual two
commuting observables [tex]J^2 , J_z[/tex] and with the help of the
su(2) commutation relations and the Hermitian inner product, one
derives the spectrum in a page or two.
Fredrik said:What would be the problem with this approach other than that it mentions Hilbert spaces?
The C*-algebra approach is not really focused on doing without Hilbert spaces, but really it is about being able to move between them.strangerep said:There's no problem if you bring in Hilbert spaces. That's (equivalent to) the standard
approach. But I'd always understood that part of the "benefit" of the algebraic approach
was that one could do without Hilbert spaces (i.e., find spectra, etc). I'm trying to discover
whether that's really correct or not, and precisely why.
I would be interested in seeing what the abstract C*-algebra of a scalar QFT looks like. I would also appreciate if you (or someone) can tell me what the three "types" mentioned below are?DarMM said:For example if I create the abstract C*-algebra of a scalar quantum field theory, states become linear functionals on that algebra.
DarMM said:In my opinion one of the major advantages of C*-algebra approach is that it allows one to see a tower of probability theories. For every type of algebra one gets a probability theory:
Type I:
Abelian: Discrete Kolmogorov probability
NonAbelian: Quantum Mechanics
Type II:
Abelian: Statistical Mechanics
NonAbelian: Quantum Statistical Mechanics
Type III:
NonAbelian: Quantum Field Theory
The abstract C*-algebra of a QFT is basically the algebra generated by the exponential forms of the smeared fields [tex]e^{\iota \phi(f)}[/tex]. Its properties are quite subtle.Fredrik said:I would be interested in seeing what the abstract C*-algebra of a scalar QFT looks like. I would also appreciate if you (or someone) can tell me what the three "types" mentioned below are?
DarMM said:The C*-algebra approach is not really focused on doing without Hilbert spaces, but really it is about being able to move between them. [...]
This allows you to analyse difficult problems. For instance free scalar field theory and [tex]\phi^{4}[/tex] have the same C*-algebra in two dimensions. However the automorphisms on that algebra are different (different time evolution or different Hamiltonian in conventional language). It turns out that these two automorphisms never have a well-defined representation in one folium simultaneously. Hence the folium the free theory is defined in (the Fock folium) is different from the folium of [tex]\phi^{4}[/tex]. This is the algebraic version of Haag's theorem.
strangerep said:I'd always understood that part of the "benefit" of the algebraic approach was that one could do without Hilbert spaces (i.e., find spectra, etc). I'm trying to discover whether that's really correct or not, and precisely why.
In summary, you do not dispose of Hilbert space, you just become detached from it and you are able to treat all states in a unified way.
A. Neumaier said:One doesn't do without Hilbert spaces but creates the latter as needed.strangerep said:[...]
A. Neumaier said:I don't like the C^*-algebraic foundations of quantum mechanics since it
assumes that every observable must be bounded and self-adjoint.
But most physical observables are not bounded.
A. Neumaier said:One handles unbounded self-adjoint operators A by considering instead the
bounded family of operators exp(isA), s real. In each representation, their
spectrum is in 1-to-1 correspondence with each other. Thus, in _some_ sense,
one doesn't need unbounded operators. But many things become quite awkward
when expressed in terms of the exponentials rather than their generators.
A. Neumaier said:My primary requirement is that the usage [of the term "observable"]
should not be too different from what physicists in general call
observables. Of course it entails always an idealization since nobody
can measure all values in an unbounded domain of results, or even all
real numbers in a bounded domain. But before the advent of axiomatic
field theory, basic observables were position, momentum, angular
momentum, energy, force, torque, etc., all of them unbounded. The
axiomatists changed the terminology for purely technical reasons, which
is unacceptable and will never find general agreement, I think.
Most of physics is phrased in terms of differential equations involving
unbounded observables. Most of physics become unexpressible or clumsy to
express when phrased in terms of bounded operators only. No commutation
relations, no continuity equation, no field equations, no Noether theorem
A. Neumaier said:[...] one can represent the unbounded observables on the nuclear space,
take its completion if the Hilbert space is needed, and the dual space
if more singular objects are encountered.
So I think the right mathematical setting should be an inner product space
on which all observables of interest are defined (this common domain exists
in all applications I am aware of), and its closure in various topologies
depending on what one wants to do on the technical level.
A. Neumaier said:[...] it seems to me that the relevant unbounded observables always
have a common domain on which they are true linear self-mappings, so
that one could work instead with the algebra of linear self-mappings of
this domain. Resolvents and exponentials would then live in closures of
dense subalgebras of this algebra under appropriate topologies. [...]
DarMM said:The existence of such a domain basically follows from the Wightman axioms,
I'll call it [tex]D[/tex]. I have never seen a study of the mappings of this
domain itself. Getting a workable specification of this domain is an open
problem in axiomatic quantum field theory. A subset of this domain and its
mappings are well studied. This domain are the states generated by polynomials
of the fields acting on the vacuum and a study of its mappings is found in
papers by Borchers, Ruelle, Dixmier and Haag. It is called [tex]D_0[/tex] .
It is a long standing conjecture that:
[tex] D = D_0 [/tex]
However this is not proven. [...]
Thanks. I was hoping that there would be an article like that. This one looks good.DarMM said:The abstract C*-algebra of a QFT is basically the algebra generated by the exponential forms of the smeared fields [tex]e^{\iota \phi(f)}[/tex]. Its properties are quite subtle.
For a discussion of the types of C*-algebras read:
http://arxiv.org/abs/quant-ph/0601158"
It will explain it better than I can.
DarMM said:For a discussion of the types of C*-algebras read:
strangerep said:Returning to the central theme of this thread, I'll extract and
summarize part of the conversation between Arnold and DarMM near the
beginning...
You (Arnold) opened by saying:
[AN - C^* algebras do not contain unbounded operators]
but, in post #135, you appear to retreat from this, (though in a vague way):
[AN - No retreat, but explaining that they are treated indirectly, replaced by their exponentials]
and I guess your emphasis in the above relates back to another quote
from your post #3:
[AN - where I say that the observables dominant in physics are unbounded,
physics is phrased in terms of differential equations relating these, while when working in a C^* algebra, all this must be given up.]
and echoed later in post #3:
[AN - saying that one can consider the full algebra, if one let's it act on a smaller spacer than the Hilbert space]
Similarly in post #6:
[AN - saying the same again]
Thus far, you seem to be advocating the rigged Hilbert space approach,
in which one defines a nuclear space as an inductive limit of a
sequence of (dense) subspaces of a Hilbert space such that arbitrary
powers of (generally unbounded) observables are well-defined on this
nuclear space. Then one considers the dual of this space, and so on.
strangerep said:However, for the many-particle case, one must presumably take an
infinite tensor product of the above? Does the Schwartz fundamental
theorem generalize satisfactorily for this case? [I.e., the theorem
that basically says [tex](S \otimes S)^* = S^* \otimes S^*[/tex], where
S is the nuclear space for 1 particle.]
I guess this question is related to what DarMM said in post #9:
[AN - where he says that a common domain exists.]
strangerep said:So is the problem that, in the field theoretic case, one cannot
(rigorously) take an inductive limit to obtain a nuclear space like one
can in the finite-particle case? And that we cannot proceed to a
generalization of the Schwartz fundamental theorem?
A. Neumaier said:In contrast to the rigged Hilbert space approach, where the base space is nuclear. I want to leave open what precisely must be required from the base space (since I am not clear about that myself). Thus I just want a vector space with an inner product, on which the algebra acts, its closure under the induced norm (which is a Hilbert space), and its dual under the induced topology. This seems to be enough to do everything needed in quantum mechanics.
There is nothing wrong with it. But proceeding the other way, one has an explicit description of the small space, and one doesn't have to worry about whether this space is or isn't identical with the nuclear space. There are lots of concrete quantum systems for which one can write down such a small space explicitly, and I don't know how to check easily whether these spaces are nuclear.strangerep said:After pondering this for a while, I don't really see the significant difference between standard RHS and what you're looking for. [...]
In contrast you want a vector space with an inner product on which the observables
act, and then find a larger Hilbert space by taking closure. You skip mention of the
nuclearity details involved in going the other way, but I wonder what this really buys?
What is wrong with using the standard RHS construction and the body of theory
that accompanies it? (It's puzzling to me that you would not use it up to the
point where it proves to be deficient in some specific way.)
A. Neumaier said:There is nothing wrong with it. But proceeding the other way, one has an explicit description of the small space, and one doesn't have to worry about whether this space is or isn't identical with the nuclear space. There are lots of concrete quantum systems for which one can write down such a small space explicitly, and I don't know how to check easily whether these spaces are nuclear.
But perhaps you know a simple criterion for checking that?
It asn't intended that way. I don't want you to actually recognize it; just though that you might have come across theorems or techniques that I could look up, which give sufficient conditions for nuclearity.strangerep said:Danger, danger. This sounds like a rhetorical teaching device
strangerep said:First, would you please give one or two of the concrete quantum systems you
have in mind, and their explicit small spaces, to focus this exercise?
http://www.photonics.com/Article.aspx?AID=45161 Inserting web link sorry if this is a double entry.JEDIGnome said:Does not observation in itself change the observation like in the quantum chip where the light bands would show up in one of two ports unless third port checked first this is done after the light has been recorded. Best theory given was the light knew where it was and knew where the other light were?
This has nothing to do with this thread. Open a new thread if you want to discuss that article!JEDIGnome said:http://www.photonics.com/Article.aspx?AID=45161 Inserting web link sorry if this is a double entry.
Again you forgot to tell us the connection to the topic of the thread, ''Boundedness of quantum observables''.JEDIGnome said:You have to be kidding me?
"Such an interconnected quantum system could function as a quantum computer, or, as proposed by the late Caltech physicist Richard Feynman in the 1980s, as a "quantum simulator" for studying complex problems in physics."
Thanks for posting it!strangerep said:[Arnold suggested privately that I should at least
post some references -- in case others are interested.]
Unfortunately, what you listed are only necessary conditions - they can be used to exclude nuclearity but not to prove it.strangerep said:Gel'fand & Vilenkin (vol 4) do indeed mention some techniques for
checking nuclearity of a space (their section 3.4).
While in earlier times, nonseparable Hilbert spaces were considered to be unphysical curiosities, they were shown more recently to be unavoidable in some cases of great physical interest: All infrared problems in QFT are related to nonseparable spaces defined by nonregular representations of Weyl groups - as described e.g. instrangerep said:Regarding item (3) above (that a nonseparable space is not nuclear), in
view of Kibble's work on the IR problem in QED involving a nonseparable
space, this no-go sounds disturbing.
Especially his recent book (of which I only learned through your notice) is relevant in this respect!strangerep said:The following two papers by Antoine appear to be an early investigation
of precisely the question that Arnold mentioned earlier
It is important since topologies that are not Frechet are hardly usable in the analysis.strangerep said:He also notes that the small space must be Frechet (metrizable topology)
for the Schwarz kernel theorem to hold (the one which says
[tex](V \otimes V)' = V' \otimes V'[/tex]. (But it's unclear to me whether
this is really an essential property for quantum theory.)
Far too technical (in contrast to Antoine's work) to make good foundations - and it depends heavily on nuclearity, which is too strong in the IR regime.strangerep said:I'd be interested to
hear what the more mathematically gifted make of it.
S. Iguri, M. Castagnino,
"The Formulation of Quantum Mechanics in Terms of Nuclear Algebras"
IJTP, vol38, no1, (1999), pp143-164
Probably obsolete given his new book. But I haven't seen it.strangerep said:[Antoine+Inoue+Trapani, 2002]
J-P Antoine, I. Inoue, C. Trapani,
"Partial *-Algebras and Their Operator Realizations",
Springer, 2002, ISBN-13: 978-1402010255
It is a generalization of the KMS state conditions for equilibrium states. But modular theory has always been too abstract for me to relate it to useful physics; so I can't help.strangerep said:I recall Bert Schroer often mentions "Tomita-Takesaki modular theory",
and I've often wonder what the heck it is. Can anyone give a
physicist-friendly overview?
A. Neumaier said:strangerep said:Gel'fand & Vilenkin (vol 4) do indeed mention some techniques for
A. Neumaier said:[Frechet] is important since topologies that are not Frechet are
I added it only because you didn't say it.strangerep said:Oh, I knew you would say that!
Thanks, that's better. But as I recently learnt, nuclearity fails in simple examples with nontrivial infrared behavior; so this seems now less relevant.strangerep said:There's also some other techniques for cases where each member of the
family of (semi)norms can be bounded by an order set of functions with
certain properties. Proving nuclearity then seems straightforward
(which G&V show for the case of Schwartz space).
This is needed so that one knows how the duals of subspaces of Fock space look like.strangerep said:I meant: it's not clear to me whether the property [tex](V \otimes V)' = V' \otimes V'[/tex] is really essential for quantum theory.
A. Neumaier said:But as I recently learnt, nuclearity fails in simple examples with nontrivial infrared behavior; so [nuclearity of a space] seems now less relevant.
The trace is undefined. A simple nonseparable Hilbert space is obtained by taking functions f(x,s) of two real arguments x and s, which hare square integrable with respect to x and vanish uniformly in x for all but a countable number of values of s, such thatstrangerep said:If one relaxes the requirement so that only the embedding map of the small space
into its closure is nuclear (trace-class), I'm wondering whether this helps in
the case of nonseparable spaces. For that matter, how does one take a trace in
a nonseparable space anyway? I guess one needs a tractable example of a
nonseparable space to study this? Or maybe the correspondence between "nuclear
mapping" and "trace-class mapping" only applies for separable spaces?
A. Neumaier said:The trace is undefined. A simple nonseparable Hilbert space is obtained by taking functions f(x,s) of two real arguments x and s, which are square integrable with respect to x and vanish uniformly in x for all but a countable number of values of s,
[tex] ||f||^2:= \sum_x \int dx |f(x,s)|^2[/tex]
It means that the sum only has countably many nonzero terms (else it wouldn't make sense).strangerep said:Sadly, I failed to discover the rigorous meaning of "vanish uniformly in x" applicable in this context.
Yes.strangerep said:I guess that summation should have been over s.
