Box sliding down a ramp question
  • Thread starter Thread starter francescalynn
    Box Ramp Sliding
A block sliding down a frictionless ramp at an angle of 11 degrees over a distance of 306 meters requires careful calculation of time and acceleration. The initial approach incorrectly used the height instead of the distance traveled along the ramp and misapplied gravitational acceleration. The correct acceleration down the ramp is derived from the formula a = gsin(theta), which leads to accurate time calculations. After correcting the arithmetic, the final time for the block to reach the bottom was determined to be approximately 18.901 seconds. Understanding the forces acting on the block is crucial for solving such problems accurately.
francescalynn
In order to get an appreciation for the time scales involved, think about a block that slides without friction down a ramp that is inclined at an angle q above the horizontal. Initially the block is at rest a distance s (measured along the plane) from the bottom. Click the button marked “DATA” for specific values of q and s. (Remember these numbers; you will need them later.) Calculate the time required for the block to slide to the bottom.
For my given values I have: distance, s = 306 m, and q = 11 deg
To find the time it takes for the block to slide to the bottom, I tried:
d = 306sin(11) = 58.4 m
d = v0t - 1/2at^2
58.4 = 0 - 1/2(-9.8)t^2
t = 3.45017
and
1/2mv^2 - 1/2mv0^2 = F*d
1/2v^2 - 1/2(0)^2 = a*d
1/2v^2 = -9.81(-306sin(11))
v = 33.38289 m/s
v = v0 + at
t = 3.44898
I can see how you tried this problem. However, when a block is on a ramp the situation is slightly different. Take a look at the attached diagram. This is how the forces are acting on this block. The force normal comes into play, and of course in this case, there is no force friction. So the only two forces in action are the weight of the block and the force normal.
Take the plane of the ramp as the x-axis, as on the diagram. Then the force normal is a y-force, the weight has x and y components. The y-component and force normal should cancel out (can you see why?) and we are left with the x-component of the weight, which is the reason the block moves. Equate that with ma, find the acceleration, then go on as you did in your solution.
Hope this helps, let me know if you have any questions! :)
This is the height of the block at its start point, not the distance traveled by the block
d = v0t - 1/2at^2
you have to correct the distance and also the accelerataion. The acceleration is not g, the block is not in free fall. Newton's laws will help you find the acceleration down the plane.
and
v = 33.38289 m/s
this looks OK
v = v0 + at
t = 3.44898
Correct the value of 'a' using the value you found in part 1.
whoops... arithmetical error
once I fixed it I got
t = sqrt(306/.5*9.8*sin(11)) = 18.901, which was correct
thank you for the help :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
