Box with mass attached to spring and board
The discussion revolves around a physics problem involving a wood block attached to a spring, where the block compresses 4.0 cm and stretches 0.9 cm beyond equilibrium. Participants clarify the interpretation of distances, noting that it doesn't matter which direction is considered positive or negative, as long as a consistent convention is applied. The primary goal is to determine the coefficient of friction using the conservation of mechanical energy principles. One participant acknowledges their approach is correct but seeks clarity on the problem's requirements. Overall, the conversation emphasizes understanding the problem's context and the correct application of physics equations.
12boone
A 0.580Kg wood block is firmly attached to a very light horizontal spring. It is noted that the block-spring system (k=160N/m), when compressed 4.0cm and released, stretches out 0.9 cm beyond the equilibrium position before stopping and turning back.
Conservation of Mechanical Energy
KEf+PEf=KEi+PEi
and
1/2kx^2
Ok, What I tried to do is solve for the work of friction using
(coefficient of friction)(Normal Force)(d)=1/2k(xf-xi)^2. However, I do not understand what the problem is asking as far as distances. I converted the distance to m but I still do not know what they mean by compressed for 4 cm. Does that mean they pushed it 4 cm forward. Let it go and it went past its resting point .9 cm. If so is .9 negative? or is 4 cm negative?
That would be correct.
However, you have failed to state what the question is asking you to find.
what I am looking for is the coefficient of friction.
Ahh right. Looking back at the question, is doesn't matter which (extension/compression) you choose as positive and which you choose as negative provided that one is positive and one is negative.
Your approach is correct by the way.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
