MHB Boy Exerts Force on 6kg Chair to Prevent Slipping
A 6kg chair is at rest on a rough floor with a friction coefficient of 0.35 and is pulled by a force of 25N. To prevent slipping, a boy exerts a downward force on the chair, which must be calculated. The friction force opposing the motion is determined by the total downward force, which includes the chair's weight and the boy's force. The equation 0.35(6g + F) = 25 is used to find the boy's force, F. Solving this equation reveals the necessary force exerted by the boy to keep the chair from slipping.
Shah 72
MHB
A chair of mass 6kg is at rest on a rough horizontal floor with coefficient of friction 0.35. It is pulled horizontally by a force of 25N. A boy pushes down on the chair so that the chair is on the point of slipping but remains at rest. Find the force that the boy exerts on the chair.
Mathematics news on Phys.org
The friction force, opposing the motion, is the coefficient of friction times the downward force In this case the downward force is the weight of the box, 6g N (g is the acceleration due to gravity, 9.81 meters per second squared), plus the downward force applied by the boy, Calling that force, F, that is a total downward force, 6g+ F Newtons so the friction force is 0.35(6g+ F) Newtons. Since the box " is on the point of slipping but remains at rest" that must be equal to the applied force 25 Newtons.
Solve 0.35(6g+ F)= 25 for F.
Thank you so much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
