Bragg Angles + Thermal Expansion
The discussion revolves around calculating the change in Bragg angle (theta) when a crystal's lattice parameter increases by 0.17% due to thermal expansion from 0 to 100 degrees Celsius. The equation 2dsin(theta) = nλ is referenced, but participants express confusion about how to apply it without knowing the wavelength or the new d-spacing. There is uncertainty regarding whether to use the relationship d_1*sin(theta_1) = d_2*sin(theta_2) for the calculation. The lack of information on density and the new angle complicates the solution process. Ultimately, the participants are seeking clarity on how to approach the problem with the given data.
exzacklyright
A crystal is heated from 0 to 100 degrees celcius, its lattice parameter 'a' increases by 0.17% due to thermal expansion. if we observe an x-ray reflection at a bragg angle theta= 19.3 degrees at 0 degrees celcius, by how much will theta change when the sample is heated to 100 degrees C. (don't need to know wavelength or d to solve)
2dsin(theta) = n\lambda
Tried using 1 for d. and just seeing how much it'd change but it didn't come out right.
Should it be d_1*sin(theta_1) = d_2*sin(theta_2) ?
well all we're given is density 1 and theta 1. we don't even know density2 or theta2
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
